Question about Toshiba Satellite P305D-S8900 Notebook
Right shift key popped off and can figure out how to put it back on
  • 50 Answers
You must see characteristic in other button, in your keyboard. Please, be carefull. And try in your right shift key.
Or, you can give your laptop and buy for a new one of keyboard.
It's done...!!!
Posted on Sep 07, 2009
  • Buddy Popeye
    Buddy Popeye Sep 07, 2009
    give your latop to that dealer, where you buy it.
2 Suggested Answers
jaye_ellen
  • 591 Answers
SOURCE: left shift key came off and cant figure out how to
Keyboard buttons that pop off can usually be re-attached by putting it back in place and pressing fairly hard till it clicks.
Posted on Oct 13, 2009
White macbook 10.5.8 pop spilled on keyboard
Ooouch ! After you've dabbed up (the spill) as much as you can, you may find some keys sticking ... i.e. when you touch (push) it (down), it doesn't pop up immediately. These are the keys you'll want to clean individually.
You can pop off the key top off (with your fingernails) from the top corner of the key. Once the key-cap top (cover) is pried open, lift the key-cap upwards and detach it from the bottom edge. You'll hear pop's when you do this. Once the key-cap is off, you'll see the mechanism under it. You'll want to clean things as best as you can ... very carefully. If the underside of the key top (cap) is sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it). Often the "stickiness" is caused by the (white translucent) plastic pieces (at the very top) not dropping flat down (immediately) after you lift it. (You wouldn't want to disassemble the parts below the (white translucent) square plastic pieces. Just clean/wipe it carefully using a cotton swab/toothpick).
You can remove the top (square plastic) pieces by pushing the tabs at the bottom corners ... downwards ... using a toothpick. This "top" square piece is actually two (square) pieces (snapped together), one inside the other. The inside piece is supposed to spin easily/quickly .... if not. it's probably sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it).
The trick is to make sure you know/remember how to reassemble the 2 pieces (after taking it apart and washing/rinsing/drying it) applying the right connection points to fit ... before you put the key-cap back on . The key-cap is put in place by just putting it in place and pressing down to snap it back on.
The larger keys (Shift, Space, etc.) has metal bars holding down the cap, etc., so it may take more effort to pop the key top (cap) off.
If you have quite a few to do, and you don't want to risk breaking anything, the Apple store is probably your next stop.
Oct 26, 2013 | Computers & Internet
Shift key was constantly sticking so everything was typing in caps. I took off the shirt key and there is a little metal bar like a one sided paper clip. Where does that go?
If the bar is what i think it is, it hooks to the keyboard to help push the shift key back up. Easy way to check if that's the purpose of the bar? pop off your caps lock, or the other shift key and see if you have the same bar there. If so, just put it back the same way it is on the other shift key.
On the other hand, if the shift key on the other side of your keyboard doesn't have one of those little bars then with all likely hood the little bar is just a little bar of something that fell into your keyboard. No worries, you can throw it away.
May 04, 2011 | Computers & Internet
The shift button popped out and I am not sure of how to put it back. I have the sony model pcg-7h1L/
Some keys will break off when they pop out, others just have to be pressed back in place. If it popped off it should just be able to pop back in without any problems. If it broke off, you'll need to get the keyboard repaired or get yourself a new one.
Jan 24, 2011 | Compaq Keyboard
Locked out of Laptop due to keyboard function keys...
I accidentally held down the right shift key for seven/eight seconds and it made all the keys function keys. I depressed the right shift key for awhile and it corrected itself.
Dec 01, 2009 | Acer Aspire 4720 Notebook
How do I shift to the blue key functions on the keyboard
I've run into this a lot myself and personally find it annoying more than useful. While typing, your punctuation keys suddenly switch to their french functions. By defaul, Vista assigns a keyboard shortcut fo changing input languages.
This shortcut is ctrl+shift - a very easy combination to press by mistake. To solve this problem, just press crtl+shift until you're back to english. You can change this shortcut or disable it all together.
Open the control panel then click "change keyboards or other input methods" under "clock, language and region". In the window that pops up, click "change keyboards..." then select the "advanced key settings" tab. This is where you can edit and disable language related shortcuts. To change one, click on the profile and then click "change key sequence". Under "switch keyboard layout", select "unassigned" to disable that shortcut.
Oct 26, 2009 | HP Pavilion dv6000z Notebook
Left shift key came off and cant figure out how to put it back on
Oct 12, 2009 | Toshiba Satellite P305D-S8900 Notebook
My "H" key popped off
ok, place the keys the right way over the cradles and gently push down until you hear them snap into place.
Don't press down too hard because you can break them.
let me know how you get on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | HP Pavilion dv4000 Notebook
Keyboard key issue in laptop
The metal bar needs to be clipped on to the plastic shift key. Look under the plastic shift key and you can see recess where the metal bar fits. Place the shift key over these recess and push down until it clicks into place.
Jun 12, 2008 | Gateway 2520915 Keyboard
Split keyboard & capslock shift function
I had a similar problem and noticed I hit the F Lock button. On mine it was a one way plunger stuck down. This caused the problems you mentioned on mine. Prying it up with a paper clip had my unit working immediately. Good luck!
Oct 30, 2007 | Logitech Cordless Desktop MX 3000...
Toshiba Satellite P305D-S8900 Notebook Logo
209 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
