Question about Maytag MGD5800TW Gas Dryer
Maytag model MDG 5800TW drum spins, but no heat. Gas is turned on
  • 113 Answers
SOURCE: Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Posted on Dec 17, 2008
mastatech
  • 478 Answers
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Check the flame sensor mounted to fire tube, its a rectagle with a glass window, also the coil can be replaced on gas valve if they are weak,
You definitly want to check the exhaust vent and vacume.
704-819-6557 for tech help and parts.
Posted on Mar 14, 2009
SOURCE: dryer runs but will not heat-vent and exhaust hoses appear clear.
Disconnect power from the dryer. Open the door and remove the 4 phillip screws from the inside lip of the door opening. Lift the door slightly and remove by sliding the hinge out from the slot on the cabinet. Grasp the front panel near the upper holes of the screw just removed. Twist from the inside out and pull away from the cabinet at the same time. Lift the front panel off of the bottom clips to gain access to the igniter. DO NOT touch the new ignitor surface as it is extremely fragile. The ignitor is attached by a single screw. Make sure the molex connector to new ignitor is secure.
Reverse the above procedure to reassemble.
Posted on Apr 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag Neptune dryer MDG 7500Aw won't heat
Replace the glow bar ignitor.
Posted on Aug 04, 2009
jan mczeal
  • 632 Answers
SOURCE: Our Maytag gas dryer drum doesn't turn. Replaced
There are three possible reasons why the drum doesn't turn.
  1. Broken belt. You replaced the so in this case it's not.
  2. Door switch. The dryer will not operate if teh door switch is defective. It is inside the drier main housing near the door frame. You need to raise or open the top or front of the dryer to reach the switch. Replace if defective.
  3. Motor. If the motor hums when the start button is pressed, the motor maybe burned-out. Check the dryer motor:
  • Check the blower fan housing for obstruction and manually turn the motor shaft.
  • If the motor is very stiff or cannot be turned manually, you need to replace the motor.
  • If the motor rotate freely, run the motor without the belt. If it runs fine, there maybe problem with the idler pulley or the clothes drum.
  • Rotate the drum by hand. If it is difficult to rotate it, correct any problem with the rollers or pulley. Reassemble the dryer and try it again.
  • If the motor hums but does not run on it's own even without the belt,but can be turned freely by hand, you need to replace the motor start capacitor or the motor itself.
Posted on Sep 25, 2009
My Maytag gas dryer is not drying my clothes Model MDG 9316 AWW. I opened and realized that the ignater works, glows and starts the flame, but only stays on for a few seconds and turns itself off, after a...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | Dryers
Gas dryer MDG 7057BWW spin but no heat
this may help:
http://www.applianceaid.com/gas_dryer.html
Oct 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune gas dryer model nbr MDG 4000 BWW. Dryer runs well but doesnt heat up. ...
A very common problem in a non-heating gas dryer is what is called the gas coils, especially if it will light briefly and then go out and not relight. You should also check the igniter and make sure there are not cracks or burned places, also thermal fuse and thermostat could cause a no-heat.
Dec 01, 2009 | Dryers
Dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Nov 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maaytag gas dryer will not go above 90 degrees F.
either your thermal cutout in the exhaust line,the heat cycling switch are bad
Nov 09, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Aug 04, 2009 | Maytag Dryers
Dec 16, 2008 | Maytag Dryers
Maytag MGD5800TW Gas Dryer Logo
56 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
