Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
In order for the washer to complete the cycle, I have to hold the lid down. We had this part replaced a year ago at a cost of $140.00. The repairman was in my home for less than 30 minutes. I am trying to avoid a repeat of this.
  • roberta3fan May 11, 2010
    has it been this way very long?
  • Whirlpool Master
  • 3,361 Answers
8054980 is your lid switch part number. It sells for approximately $30.00. You can replace it yourself.
Posted on Sep 05, 2009
Why does washer not complete cycle & lid not unlock?
Probably leaked thru tub bearing on tub and got into cluth, ur lucky to have this washer for as long asyou have costs more to repair than replace either way if that your problem
Jul 12, 2014 | Maytag Neptune FAV6800AW Top Load Washer
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
My mvwc300vw1 won't spin unless you lift the lid up to activate it
I'm not sure what you mean by "activate it." Are you are manually pressing down on the lid switch or are you saying that lifting the lid starts the spin cycle? You may just need to adjust it. For whatever reason the actuator on the lid isn't pushing the switch far enough to activate it. It is possible that the actuator broke in some weird way that makes it contact the switch when the lid is opened. Regardless the spin cycle should cease when the lid is opened. The actuator is the wire hinge on the left side of of the lid. They always break where the screws connect them to the lid so you should be able to see it by lifting the lid. You can go here for manuals and exploded views of your machine. The hidden lid switch and actuator are clearly visible if you click the "Top and Cabinet" diagram.
Now i want to say something about your machine. First to be fair i don't know what the reviews of this machine might have been and I've never owned one, but if it serves you well hold on to it. Maytag doesn't make them like that anymore. In fact Maytag doesn't really make them anymore. That repairman died years ago and was never replaced. I'd take a machine like yours (with manual controls and no brain) over every smart h.e. machine i've ever had the misfortune to work on or operate. Sure they save water and they are quiet now but the drain pumps are junk fixing to bust and in my opinion the reason people experience mold and odor problems. They oversuds chronically and then have to sit while the machine decides when and how you can proceed. Doors lock shut at the most inopportune times. Control boards cost hundreds of dollars to replace and diagnosing problems on a "smart machine" can sometimes be more than a little baffling. So treasure it. Just sayin.
Jan 01, 2013 | Maytag Atlantis MAV6000 Top Load Washer
THe Washer is shutting down before wash cycle complete
If this is a Whirlpool manufactured TOP LOADER, you need to check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
May 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care II lsq8500JQ1 top...Problem
Ok folks to change the lid switch on these and many top loading Whirlpool, Maytag, Kenmore, etc is quite easy.
Steps to replace the lid switch:
1. Remove unit from AC.
2. Remove the loading door from the unit, or using some duct tape tape it closed.
3. Using a small flat bladed screwdriver find the 2 release catches on the front of the unit between the top cover and front panel. These are just snap claps to hold the top cover down. To release the top you will need to compress the latch using the screwdriver. Start with one side, then the other. Once you have released both clips the lid will lift up just like the hood of your car.
4. You will now be able to remove the lid switch from the unit.
5. Install the new switch and close the hood of the unit.
6. Test the repair by running the unit though a complete cycle.
A great place to order the replacement part for the unit is:
www.appliancepartspros.com
They ship same day on orders placed before 3pm EST. Overnight shipping is available, however I usually opt for the 2-3 day ground shipping and save the money.
If this switch replacement does not take care of the problem, you might need to replace the control board located under the front panel. This replacement is also very easy and takes about 10 min from start to finish.
Hope this helps everyone. Cheers,
Keith
Oct 19, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Over 17 days waiting for a Baton Rouge, La. Stanton Appliance repairman. The repairman said he'd order the part and it would come in two or three days. I call about it 7 days ago and they said only one...
CALL 1-800-905-9505 FOR A&E FACTORY SERVICE
cancel the call with the other servicer they will come out and fix the issue for you this guy is guessing on the repair that you need a&e will get it right
Apr 19, 2008 | Washing Machines
Kenmore Elite Extra Heavy Duty Calypso Top Load Washing Machine
I had this problem and did not have the time to fix it myself so I called Sears. The "tech" looked at his laptop, called his "supervisor" a couple of times and told my wife that both control boards needed replaced at a cost of over $500. The manuals, with testing procedures for the inclined, are on the inside, front cover.
The CE error is a communications failure and on mine it required replacement of the AVS board. I bought the part at a local supply house and replaced it myself for about $175.
Jan 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 80 series heavy duty super capacity plus
Check the lid switch when you lower the lid you should hear a small clicking sound.
Sep 22, 2007 | Kenmore 22422 Top Load Washer
Washin machine not spinning
Your repairman is correct. The problem is a rusted spin bearing just under the tub. It is only in use during the spin cycle. Parts are about 50-70 bucks but it's a very difficult job and out of the range of the average do-it-yourselfer. Try to use the machine almost every day to prevent the bearing from freezing up. That way you can get a few more months use out of it before replacing it. If it does freeze up, try to turn the basket manually. It won't move much when its stopped because of the brake. Your repairman probably turned it during the spin cycle by defeating the lid switch.
Nov 06, 2006 | Maytag Atlantis MAV6451 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal De
