Question about Marvel 6BAR-BD Beverage Cooler
Cannot remove the lower racks to replace the trough at the back
I have to get the bottom racks out to replace the trough at the back of the unit, but cannot. Is there some trick to it?? It's a Marvel 6SWC6001 wine keeper with glass frame door.
  • subdriver May 11, 2010
    What is the serial number of your unit. Marvel changed the design of those racks about 4 times between 2000 and 2008. Normally there is a release latch near the end of the slides. You push/pull to release/lock then pull the rack fully out. If you get me your serial number I can find out which racks you shold have.
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
  • 101 Answers
SOURCE: Marvel wine refrigerator running,but not cooling
If your unit runs but does not cool, you have a "sealed system" issue. Either you are low on refrigerant which would be evident by frost build-up near the area where the freon first enters the evaporator plate. (lower middle, then travels left) or the compressor has lost the ability to develop the necessary differential pressure. You do not want to run the unit like that...you can **** in contaminants that will harm the compressor if you already haven't. You should contact a servicer to get it repaired. If you are still within the warranty period you should contact the dealer you got it from to initiate service.
Posted on Sep 15, 2009
  • 101 Answers
SOURCE: Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Posted on Feb 05, 2010
How do I change the bottom radiator hose
Do not attempt while engine is hot, basically easy, a couple tools , drain pan and rags, new antifreeze
check links below, press the helpful button.
2001 Dodge Dakota 4 7L Changing the Lower Bottom Radiator Hose and...
How to Replace Radiator Hose Upper and Lower
Jan 26, 2016 | Thule 2004 Dodge Dakota - Quad Cab, with...
Frigidaire gallery dishwasher not draining
Perhaps the screen in the bottom is clogged. Remove lower rack and lift off spray arm. Remove screen and clean then replace. Replace spray arm and rack. Always rinse food from plates, etc. before loading dishwasher. Not everyone does this in my house and I tell them not to be so lazy. For more serious issues try "RepairClinic" their site is really good.
Oct 15, 2014 | Dishwashers
Frigidaire/electrolux dishwasher not cleaning top rack
There is a circulating pump that takes water from the bottom and pushes it to the top spinner. Most likely that pump is clogged or needs to be replaced. Replacement is a somewhat involved repair that requires removal of the lower pump assembly. It can be done DIY if you are comfortable with disconnecting a/c power to the unit, removing the unit and making tight hose re-connections. Before you do that - maybe check the intake for clogs that may be slowing the water flow. Have you routinely cleaned the bottom intake? (Most likely not ...) You can start by cleaning the bottom intake by usually removing the lower spin arm, then take out the catch ring and check for obstructions. The spin arm rests on a cap that can be removed to then remove the screen assembly. Be careful not to force the part in the wrong direction - with these you usually turn the spin cap right to unlock from the base. Then you can access the intake area - be careful as there are probably blades inside the intake that work as the disposal grinder. Remove the soap scum and buildup on all removal parts with a simple sponge and baking soda scrub. Do not attempt to run the machine with parts removed.
Sep 05, 2014 | Frigidaire Electrolux EIDW6105GS 24 Fully...
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
Dishes in the top rack not getting clean. Bottom rack is fine.
Your filter/chopper is clogged. You have to clean it out and that will restore water pressure to the top rack.
  1. Remove the bottom rack.
  2. Remove the top rack
  3. Remove bottom Spray arm (turn top nut clock wise)
  4. Take off the delivery tube by turning it clock wise over the heating element ( undo the two clips one at the back and one on top)
  5. Take out the screw for the top screen and remove top
  6. Take one screw out for chopper housing and remove
  7. Remove chopper and clean or replace chopper if broken
Reinstall all parts and test.
That should help please rate your experience. Thanks
Dec 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
WATER COMING OUT FROM THE FREEZER SIDE
You most likely have a clogged drain,turn off or unplug the unit Remove the shelves a racks from the bottom half of the freezer section You'll see a metal panel at bottom  at the top of this panel are two screws,remove those and tilt up the plastic panel so you can remove the bottom panel.
 Once that is out of the way you'll see Ice built up in the drain trough at the bottom don't poke around with anything sharp but you can tap the ice with a screw driver handle and break it up for removal,once the ice is removed pour a cup of hot water into the trough to thaw the drain,when it thaws the water will run into the pan under the unit and evaporate
Sep 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
How do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Mar 13, 2009 | GE Refrigerators
LG dishwasher does not seem to clean items on lower rack
Can you tell me if the problem was fixed by the original posters?
The multi-level wash direction feature uses a check valve just below the mesh filter asembaly and is driven by a vario motor underneath the check valve. By removing the mesh filter (10 screws and the lower spray arm) you expose the check valve. It is very close to the pump that empties the water through the drain hose.
High probability problems: -The Check Valve could be jamed/stuck. -Also, the Vario Motor could have failed
Please respond back with the findings on this problem. Thanks!
Sep 29, 2008 | LG LDF6810ST Stainless Steel Built-in...
Does not clean dishes on top rack
DG:
There is a rubber boot connecter in the back of the top rack which slips over a pipe coming up the back of the unit. This is how the water gets to the top rack. That boot is subject to rot and breaking. Check and see. It should be easy to replace, if you can get the part.
May 11, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Top Rack always slides out fully
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
Jun 19, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Marvel 6BAR-BD Beverage Cooler Logo
52 people viewed this question
Top Marvel Refrigerators Experts
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
