Question about Miele Novotronic Premier 500 Front Load Washer
Inlet blockage red light flashing
We have a Miele W970 Novotronic washing machine. Inlet light flashing red. We have cleaned both the inlet and outlet filters but problem persists. Can anyone advise what else we can try?
  • roberta3fan May 11, 2010
    when you wash clothes will the water come in normal or is is very little flow?
    Problem Solver:
  • 8 Answers
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
  • appin Oct 26, 2010
    Inlet light can also flash if insufficient water comes in -- can mean a failed solenoid valve or lack of power to the main solenoid. Try half- filling using a hose (into the powder dispenser) immediately the red light starts flashing. If machine proceeds with the programme then clearly the main wash solenoid is either not working properly or isn't getting a signal from the circuit board.
  • Lucy marshall Nov 09, 2015
    Thank you very helpful just done this in my machine and it's working again!!
SOURCE:
I have a Miele Novotronic W 828 the check inlet red light is flashing - what do I do?
Hi dear. Seems to me your machine needs new inlet valve replacement.Due to it's age, it's quite normal. Thanks.
Jan 26, 2016 | Miele Washing Machines
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Miele W828 Check inlet red light flashing
Just wanted to mention mine was retaining the fabric softener and skiping steps in the cycle and intake red light was flashing too. Once
I cleaned the draw and used a toothbrush to unblock the holes in the ceiling its working again perfectly. Miele Novatronic W 828.
Mar 07, 2013 | Miele Novotronic Premier 500 Front Load...
Miele novotronic w145 s spullen light flashes
Possible that this error can be due to the INLET or the DRAIN being clogged or is not functioning. Remove and clean the filter to both the inlet and drain.
Jan 19, 2013 | Miele Washing Machines
Miele Novotronic W 844 Washing Machine
Pete,
When I had this problem I went along the entire water inlet route and verified flow. Water flow entering the soap dispenser tray should be very robust & audible; if not, you have a flow restriction or low pressure, flashing red light or not.
I'm stating the obvious because I actually missed some filter elements the first time I tried. Disconnect inlet hose at plastic fitting on chassis and verify your flow there. Then look inside the inlet barb and use a small pair of channel lock or lineman's pliers to grasp the tab on the inverted "basket" and pull it straight out. These filters can be packed full of sand and small gravel inside--they were in my case.
Good luck,
Adam
Aug 03, 2008 | Miele Novotronic W1918A Front Load Washer
Check Inlet
where the water lines attach to the washer at the back un screw them and check the screens on the water valves see if rust or trash is restricting the water flow
May 24, 2008 | Miele Novotronic W1918A Front Load Washer
Water inlet flashing ,not filling, Miele Novotronic W939 Super
Hi Paul,
We currently have a similar problem with our W939. I took the front panel off and found that the Miele service folks had incorrectly routed the ribbon cable linking the fill level sensor with the control panel and severed one of the wires. The machine was reporting a series of errors, one of which was an outlet blockage and the discharge pump was not working.
The relevance to you is that your problem may be a loose or broken wire or corroded terminal.
SA.
Apr 14, 2008 | Washing Machines
Miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
1,853 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
