Question about Dacor ECS127 Epicure Stainless Steel Electric Single Oven
Inside Window Replacement
The inside window of me DACOR cracked and I have the replacement part but for the life of me I can't figure out how to get the old one out and the new window in. It looks like the inside framing for the window should just pop off but it resisted and I didn't want to push it...any help is greatly appreciated. Thank you everyone.
Remove screws from top panel it is presure into slot by force screws. then slid flat blade alog egde without forcing it. untill it releases. once you have clean and reverse proces to install make sure screws are tighten. like you would tighten a tire rim on a car.
Posted on Dec 08, 2007
What does a C76 or C77 error code mean on a Dacor wall oven?
Page 9-48 in technical manual excerpts at the link below:
http://www.uncleharrywizard.com/nephewclub/WizardRange/dacor/dacor-wall-oven.pdf
It says to call for service (by a technician). (I am only reading it from the document - I am not a technician.)
It says to replace glass/touchpad assembly.
It says wrong or unrecognized diode configuration.
Apr 03, 2018 | Dacor Ovens
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Jul 12, 2016 | Dacor Epicure 30" Double Wall Oven,...
F-1 showing on digital window of dacor dual fuel range with oven alarm beeping. Unit is turned off.
Your temperature censor may need to be replace. try geting the fault code diagram from the manufactor brand.
Nov 14, 2013 | Dacor Ovens
Oven displays F4
F4 on a Dacor oven is a bad temperature sensor.
The temperature sensor is inside the oven up high on the back wall.
Jan 16, 2010 | Dacor Ovens
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
Dacor ECS136 Control panel just beeps but does not work
i am having that problem with my maytag one. the only thing i can do is unplug it and quickly press bake and set the temp and time length. mine says its locked though. i am trying to figure out how to unlock mine.
Oct 30, 2008 | Dacor ECS136 Epicure Stainless Steel...
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Dacor error codes
HI. the F-1 code is a System Watchdog Circuit failure code.
Press "Cancel", if beeping continues after 30 seconds, replace the main control board (also called clock or ERC).
Concerning the F-5 code. This is an oven temp sensor failure code. have it replaced asap. ((Check the wiring leading to and from the control and sensor for cracks and fouled structure. if the wiring is bad, replace the harness as well)),
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Inside oven lights won't work.
Hey,
I went to the appliance store where I purchased the oven, and they called a Dacor representative. A flat end tool was given to me to pop out the plastic covers. There are no screws to fasten the covers, so you have to use this tool - which was not put in my kit at the time. Be careful when doing this, because the plastic cover can break. You replace the bulbs by pulling out and pushing in the socket. There is no turning the bulb. Handle the bulb with a paper towel, because the oil from your hands will take life from the bulb. Very important that the oven's breaker is off before this is done. Luckily, I had a very kind clerk helping me, and she even gave me the bulbs free of charge.
I like your website, and I will use it again in the future.
Feb 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
Oven enamel chipping
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Jan 12, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor ECS127 Epicure Stainless Steel Electric Single Oven Logo
87 people viewed this question
Top Dacor Ovens Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
pvfjr
Level 1 Expert
Are you a Dacor Oven Expert? Answer questions, earn points and help others
