Question about Mirro Coffee Makers & Espresso Machines
I am looking for the Telyfon Frying Pans with the wooden handles -- My are old and I want to get new ones -- Do you still make them?
  • 58 Answers
Teflon has recently been determined to be toxic when used as directed during cooking.
If it has not been banned where you live it should be or will soon be.
Posted on Sep 05, 2009
THE GREEN FRY PAN DOES NOT CLEAN AS SHOULD BE.WE;;
I'm convinced that actually all these "non-stick" pans are scam. All of them look very nice at first and then they start to stick and get black. I have the same problem with rather expensive ceramic nonstick "marvel" I bought last year.
Some time ago I bought a really good nonstick pan but it is very big - 15"! After I found out that it was what I've been looking for, never could find the same type in a smaller scale.
So, I presume, just should continue testing till we get the real one
May 12, 2015 | Ozeri 10-in. Ceramic Nonstick Green Earth...
Loose pan handle
Look at whe pan where the handle meets the pan. There may be a screw that takes either a flat blade or phillips screwdriver fitting. If it is there, simply screw the handle back in until it's tight and you are done.
Apr 13, 2014 | Home
Cleaning glass lid for SS frying pan. Surfaces are clean but svere spotting still exists is this doubkle wall glass???
Use Dawn dish soap, rinse in as hot a water as you can handle and dry immediately with a cotton or linen towel. Should work.
Mar 13, 2014 | Home
The rubber handle on my frying pan has become sticky
Wash it very well in as hot a water as you can handle using Dawn Dish soap, rinse in as hot a water as you can handle and dry immediately. Re-was as necessary to remove the stickyness.
Dec 02, 2013 | Home
Sticky black handles on Farberware frying pan
I tried the grease cutting soap to no avail. Decided it needed a more aggressive approach. Since the suggested cause was grease, I decided to try my automotive brake cleaning spray. That did not wash the surface but it did soften the surface enough to discover the culprit was a deteriorated coating Farberware put on the handle. The brake cleaner was effective in softening the coating such that I could use my finger nail to scrap it off. I now have a smooth non sticky handle.
Nov 24, 2013 | Home
What are frying pans made out of?
They can be made out of a lot of things but most are copper, Teflon or tin.
Jan 10, 2013 | Home
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
Can i refurbish my non stick pan. Some of my friends used a knife and made some nasty marks. can i get this fixed
At best you can recycle. Once the skin of the coating is compromised, there is little or nothing you can do to re-coat the surface with a coating such as the factory coating.
I use pans with compromised seals as a double boiler when making candles. I put my wax pot in the frying pan, fill with water, then melt my wax. I do not care of the pan gets wax on it because I no longer use it for cooking.
I also use larger frying pans pans with compromised seals under the car when I drain oil. I allow the oil to drip (provided it is less than 4 qts.) into a plastic milk container that I cut the top off of. I set the plastic container into a large frying pan that I no longer use. The handel on the pan makes it easy to slide out the plastic container once it is full of oil. I then take a funnel and transfer the oil into another milk jug or old 164 oz laundry detergent bottle that still has the threads for the plastic cover in tact. I mark it used oil and set it aside in the corner of the garage for when our community allows for the annual oil and chemical waste pick up.
My dad was an avid hunter...he used old frying pans for target practice when on the country land...he'd hang pans from the handel and shoot at the pans he hung.
Sorry this is the best I could do.
Being a mom that has gone though this enough times....I removed all my metal utensils from the drawer next to the stove with plastic ones hoping my kids would grab the closest which are now plastic that is heat tolerant.
Mar 20, 2011 | Microwave Ovens
They are pitted and food sticks - Need to get new ones - how
call them they can look up her acct number from zip and last name or her phone number if it is not the same as it is now she would need to know the old ones then they can tell you what to do
Apr 26, 2009 | Kitchen Ranges
Stopping the self-clean function after starting in erro
You don't have a cancel clean button on it? If not, you may have a reset button in the back of the oven. Otherwise, you may have to let it "run the cycle". Hopefully, you don't have wooden/plastic handles on your frying pans.
Dec 29, 2008 | Whirlpool RBS245PDS Electric Single Oven
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Mirro Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Mirro Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
