Question about Omron HEM-711 IntelliSense Automatic Blood Pressure Monitor
OMRON Model Hem-711's display is messed up. Over one-half the top of the numbers are not showing. Is there a fix for this, or should I scrap it. I assume it an eternal problem in the window (Liquid diodes/crystals? - I used to know what they were called). Larry
Same problem on my Omron HEM-711. Manufactured in 2003, past the 5-yr warranty. Cust Suppt told me to replace unit. I opened the unit up and looked inside. Two very tight phillips screws, one on back panel, other in battery compartment. Case pries apart. LCD display looked intact, ribbon was undamaged. Unit appeared to work properly, just did not display correct reading, some of the liquid crystals in a few of the digits were not activating. I installed batteries with case still open, turned power on while pressing ribbon along edge of circuit board. Ribbon is manufactured with glue to circuit board, some of the leads come loose after several years due to manufacturing defect. In my case, pressing towards the bottom side corrected problem. You can see when it's working properly because all the display crystals light up simultaneously when unit is first powered up. I clamped down ribbon with two small paper clips insulated with a few bits of paper, works fine now, saved eighty bucks.
Posted on Sep 27, 2012
  • Andi Jan 11, 2013
    Dear robbie257. Several months ago my Omron did the same exact thing that yours did. I pressed along the bottom of the ribbon and voila, same problem. I only needed one clamp, not paperclip, insulated with a bit of paper and it works fine...saved me eighty bucks. Thank you so much.
  • Andi Jan 11, 2013
    I forgot to let you know the type of clamp used. I was afraid that the paper clip would slide off so I used a small alligator clip with teeth (attached).
    New Friend:
Machine was out of warranty as is mine, which was purchased in 2007 (5 yr). I've found 2 screws underneath mine in the front but none in the battery compartment. Top / bottom will not separate and feels like there must be 2 more screws but don't see them. Anyone know how to get apart without damaging the unit? I have the same issue as above with the led crystal display disappearing. Otherwise, it appears to be functioning correctly.
Posted on Jan 06, 2016
  • 22 Answers
Omron must replace it for you free of charge.
Posted on Sep 06, 2009
Only memory works on y HEM-711 start stop button does not work . Is it worn out?
Time for a new machine. That could be the controller or the switch board that is bad. You cannot get parts.
Oct 06, 2016 | Omron HEM-711 IntelliSense Automatic Blood...
Please give me a price on Omron hem-711 automatic blood pressure monitor
Look for them on E-bay. They are very inexpensive there. Also, Walmart sells them for about $57. I saw one on Ebay for $17.
Feb 19, 2015 | Omron Health & Beauty
I am using OMRON Automatic blood pressure monitor Model No HEM-711 Now it is not working. Where can i get it repaired. I am staying in Calicut Kerala
Not sure it would be economically repairable, but you can reach Omron customer support here: http://omronhealthcare.com/blood-pressure/?utm_source=google&utm_medium=cpc&utm_campaign=g%20-%20us%20-%20nam%20-%20omron%20-%20ps%20-%20branded_search_bp%20home_broad+bp%20home&utm_term=+omron%20+blood%20+pressure&gclid=Cj0KEQiA4OqnBRDAj9aazvPji9ABEiQANq28oF_sSD--daREzE00Wlci06zN6u8WOJVwE5T4LZBud6waAgS68P8HAQ
Nov 01, 2014 | Omron Automatic Blood Pressure Monitor w/...
Can you calibrate omron hem-711
I check the accuracy of my Omron every year. It is important that your device must give proper results.
Jun 04, 2012 | Omron Automatic Blood Pressure Monitor w/...
My Omron 711 seems to register readings that are too high when compared to doctor's office or monitors in drug stores, etc. Is there a way to check accuracy of the monitor?
Take the cuff to your doctors office and have the nurse check with yours and the office BP cuff. If your cuff is too small, you will get a false high reading.
Nov 30, 2010 | Omron HEM-711 IntelliSense Automatic Blood...
I have omron arm blood pressure monitor, wehre in Digital display - numbers are not showing properly. It gets cut. where should I get it repaiers i Ahmedabad, India. Or what is the solution to get it...
I HAVE A OMRON MANUAL BP MONITOR MODEL HEM 432C. THE DISPLAY IS NOT COMING PROPERLY. I WANT TO GET GET IT REPAIRED. PLEASE LET ME KNOW THE NAME AND ADDRESS OF THE DEALER IN THANE OR MUMBAI.
Oct 11, 2010 | Omron Automatic Blood Pressure Monitor...
How to read the machine omron hem 711
There are 3 major things, Systolic/Diastolic and Pulse. You want the numbers to be 120/80/varies...... anything outside this is considered an alert and should be brought to your Dr's attention
Jul 30, 2009 | Omron Healthcare 2007 Hem 711DLX Automatic...
Assistance with a omron hem 711
Use it, works great, quick, accurate.
Jul 30, 2009 | Omron Healthcare Omron Hem 711DLX...
Omron HEM-711 IntelliSense Automatic Blood Pressure Monitor Logo
1,460 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
