Question about Boating
50hp force that jumps in an out of gear - Boating
    Sniper:
  • 53 Answers
I need year model to be precise? But here are the basic tools and troubleshooting steps. TOOL (1) a black marker.(2) a tape measure (3) a second person. TROUBLESHOOTING STEPS(1) the force need water so put it in the lake or install water hose.(2) do not start engine yet. remove engine cover and find shift cable by shifting remote control. once you find were the shift cable connects to the shift linkage. learn which way is forward and reverse. is it push or pull by the cable. remove the cable.(3) now the shift mechanism is removed from the boat controls. this test will require you shifting the shift linkage by hand so stay clear of the flywheel and all moving parts. (4) start engine. at idle speed and you in a safe location near the shift linkage shift engine into forward gear by the shift linkage. be aware how far you need to move the linkage before it shifts into forward. Mark that location with the maker somewhere you can see.(5) shift the linkage back to neutral. mark location were neutral begins. you will fill it click out of the forward gear.(6)now shift into reverse gear marking that location.(7) shift it to neutral making that location as you fill it leave the gear(8) shut off engine turn off water or take it out of lake (9) look at you marks and measure the distance between neutral and forward. the measure the distance between neutral and reverse(9) the second person needs to be in the boat to work the remote control. you need to be at the engine with the tape measure. person #2 needs to make sure remote control is in neutral. you need to measure the remote control cable end so you get a measurment with it in neutral. make a note of the neutral lenght.(10) person #2 shift remote control into forward gear. you measure cable end for distance traveled to go to forward.(11) make the measurement for reverse same way.(12) this is how you find out if you clutch dog is to wore out to stay in gear by the travel of the shift linkage compared to the travel of the shift cable. There are adjustments but they only go so far. that means you will have to sacrifice one gear for the other to make up for the distance of travel.
Posted on Nov 04, 2009
I have a1973 50hp evinrude electric shift is there any way to take the motor out of gear manually
The electric shift were a drama?
The solenoids that control shifting sounds like one has packed up?
try dropping the leg and determine which one is at fault?
or see if the wiring under the cowl is ok? From memory no power is forward gear ?
try direct to battery and bypass the loom?
Good luck.........
Oct 20, 2015 | Boating
Wat is the spark plug gap fo 50hp mercury two stoke 2009
The plug gap is most likely .040, however can you please confirm your serial number?
Sep 10, 2014 | Mercury Force Tilt Trim Motor, 25-50 HP...
1985 Johnson 50hp slipping at times when accelerating. any clue?
check the condition of the gear teeth in the gear box. check that the selector is full engaging the gears (rust-corrosion etc). IF you have a rubber mounted prop then check that the rubber hub is in good condition
Sep 08, 2014 | Optics
Cant get car into gear
The Syncro Gear in your Transmission is probably gone. Requires a rebuild. The Syncro is what aligns the metal gears inside the transmission and allows you to shift smoothly between gears and to get the alignment right. When you FORCED the shifter, you did more harm than good...
Mar 01, 2014 | Toys
Starter motor wont work evinrude 50hp 2cyl
Sometimes there is a switch which prevents the starter from working in gear. This switch could be out of adjustment. Otherwise you need to check for a bad relay by jumping the one you can find and seeing if the starter will turn. Check the grounding on the motor too.
Feb 01, 2012 | Boating
I have a mercury outboard 50hp engine that will not start
If you are saying the Flywheel is locked or Frozen then I imagine the starter Bendix was found extended and jammed against the Flywheel.
If the motor ran when it was shut off last, then your rings and/or bearings rusted in place. You don't want to grab the prop to turn it because it will strip the Rubber hub.
I would take out all the spark plugs, tilt the engine up as close to level as you can get it and spray WD40 into the cylinders. If you did not have water connected to the engine the pump may have crumbled but if the engine did not turn at all the pump may still be good.
Give the WD some time to penetrate and crank the engine to see if it broke loose. If it did not, you may as well drop the lower unit and eliminate jammed gears with a second try at cranking the engine.
If still no luck, you might try to rig an Air fitting to the Sparkplug holes and hit each with about 80PSI and another squirt of WD. This will force the WD deeper and force the pistons down with no damage.
Still no luck, then its disassemble time. Good luck on this.
May 27, 2010 | Boating
Hi i am having a problem with my cd player, it does not play any cd's. My son accidentale forced the top door of unit it closes put not as smooth as before, what could it be.
sounds like the door has jumped a tooth on the drive gear. it will never line a disc up properly. you need to get it back to its original location try jumping it forward or backward one tooth at a time. opposite of which direction it was forced. this is very tricky who knows how many teeth it jumped. trial and error. just remember one tooth at a time till u get it right.
Feb 19, 2010 | Bose Lifestyle 12 System
Got a rm250 1999 its keeps jumping out of secon gear wen the power ban kicks in
Unfortunately, this most likely means that you've got worn or damaged parts inside the transmission - which also means that the engine has to be removed and disassembled.
With the transmission parts removed, check for rounded edges on the gear "dogs". Having straight edges on the dogs is what keeps the gears from sliding apart and the transmission from jumping out of gear when power is applied.
Also check the shift forks for wear and straightness. When your transmission jumps out of gear, excess force is applied to the shift forks, causing wear and sometimes bending.
Jan 01, 2010 | 2003 Suzuki RM 250
Need online repair manual for evinrude 50hp outboard
how can I adjust the shifting linkage on my 50hp evinrude. I have the cable adjusted all the way out but it will not go into reverse
May 10, 2009 | Boating
Boating Logo
232 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
