Question about Epson Stylus C66 Inkjet Printer
No ink on paper
Head cleaned, new cartridges installed and it is still printing out blank pages What could be wrong?
3 Suggested Answers
Basti
  • 1447 Answers
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
  • 526 Answers
SOURCE: Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
thanks
Posted on Dec 17, 2009
No printing is made only blank paper is coming out
Hello
1 Clean Print Head
The print head gets clogged due to frequent usage. Therefore, the ink will not be able to get out of the cartridge. Hence, the printer only prints blank pages. The solution to this problem will be to clean the print head. This can be done by cleaning it with a damp cloth or with an Iso Propyl Solution.
2 Check if Cartridge is Empty
If this does not work, your next step would be to check if there is any ink in the printer cartridge. You might be giving a command for a high resolution printout, but the ink might not be enough for such a purpose. Look out for the printer prompts that will tell you about the low levels of ink.
3 Install the Correct Printer Driver
Many a times if you are downloading a printer driver from the internet, you might download the wrong driver. This will result in the computer not recognizing the printer. The result is blank pages.
4 Check for Appropriate Paper Size
Another facet to be taken care of is the paper size. You must check the Page Setup Dialog box whether you have selected the settings that are in tune with the paper size that is being used for the printing.
5 Check the Operations
If nothing works for you, then a printer operations checks is in order.
THANK YOU FOR VISITING FIXYA
Jan 30, 2011 | Office Equipment & Supplies
My printer is only printer blank pages? When it prints, it runs the paper through at a rate as if it was actually putting ink onto it but than the paper just comes out blank. Help!
Check the ink cartridges for ink level - it might just be empty. If you've replaced them with new cartridges already, clean the print heads with a "Q" tip and alcohol and run the "clean-cartridge" function in the printers properties.
Nov 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
When I print only a white page comes out, with no text. Do you know why this happens? It just started 2 days ago. It's not an inc problem.
STEP 1: Clean Print Head
STEP2: Check if Cartridge is Empty
STEP 3: Install the Correct Printer Driver
STEP 4: Check for Appropriate Paper Size
Another facet to be taken care of is the printer size. You must check the Page Setup Dialog box whether you have selected the settings that are in tune with the paper size that is being used for the printing.
Jan 13, 2010 | HP DeskJet 9800 InkJet Printer
I refill my epson C60 cartridges and have a chip resetter. Now, the cartridges won't release ink when printing. I get a blank page. The printer recognizes the cartridges. What is causing the blank page?
Put the ink cartridge onto a damp paper towel.
Does ink "bleed" onto the paper towel?
If not, then the print-heads are clogged,
and you should run the "head-cleaning" software (part of the software package for the Epson printer).
Dec 30, 2009 | Epson Stylus CX8300 Printer
thanks
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
My printer is printing blank pages What is wrong?
You may clean the cartridge by following the steps given below:
1. Remove the cartridge or cartridges from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridges back into the printer.
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Disconnect the power cord from the back of the printer.
2. Press and hold the button on the printer panel.
3. Reconnect the power cord and keep holding the button on the printer panel until the printer starts to pull paper.
4. The printer should now print a test page. Please note that the test is continuous. To stop the test, disconnect the power cord.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Apr 16, 2009 | Lexmark Z617 InkJet Photo Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Nov 16, 2008 | Epson Stylus C66 Inkjet Printer
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Epson Stylus C66 Inkjet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
