Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
REMOTE WILL N0T CHANGE CHANNEL? HOW TO FIX? - Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
  • 10,594 Answers
Does remote change volume level or can open Menu in TV?
If yes, then its specifically channels buttons that do not work in remote and new remote would work.
Posted on Sep 05, 2009
My TV says Channel Fix how do I get RCA Universal remote to change channels
There are manual controls for the channel change on the TV just look.
Sep 29, 2016 | RCA Televison & Video
Can't change channel, get to list, or guide with Logitech remote
open the remote control and clean the keypad for dirty, oxide, corrosion, and bad contacts.
2) replace new batteries ALKALINE , full charge
3) retigh the springs contacts batteries, with long pliers for better contacts.
4) try again.
5) otherwise you must go to the repair shop TV for fix it.
God bless you
Oct 01, 2012 | Logitech Harmony 900 Remote Control
TV is on one channel and will not work with remote or allow me to change channells from side of tv
I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
Jun 25, 2011 | Element Electronics FLX2211B 22 in. LCD TV
Can't get the channel to change so that the cable works, it's stuck on Channel 4 and needs to be Channel 3
i take it you dont have a remote and your control panel is not working the best fix for this is to go and purchase a cheap universal remote control and program it to your tv this will allow you to change channels
Jan 02, 2011 | Toshiba MD20FL1 20 in. TV/DVD Combo
The tv is on but the remote control does not work. I thought maybe it was the remote control that came with the tv so i went and bought a compatible universal tv remote but that does not work either so i...
I have the same problem as you Lisa and am beyond frustrated....any fix found yet? I think it is the receiver in the tv as even the remote that came with the tv won't do anything but turn it on/off...no channel change or volume control. The cable co remote will do volume after tv warms up....
Apr 10, 2010 | RCA L32HD31 32 in. LCD HDTV
RC00013 remote, channel change and power not working, how to fix?
hi,
your power button lose its contact or misplaced to its proper position. open your remote control and turn back your power button it its correct positioning. having a new one is probably the instant solution to your problem.
regards,
kaybicks
Feb 27, 2010 | One For All URC-4605 Remote Control
The tv is stuck on channel 3 and i want to change the channel and i have no remote. How do i do it? I have a magnavox tv dvd/vcr vcr recorder model 20mc4304/17
This is hard but understandable. If you cannot change it on the frount of the unit with the channel up and down buttons then you may have to get a universal remote there is no solution or quick fix or any type of factory reset unless you had the remote to get into the menu. good luck
Apr 22, 2009 | Philips Magnavox DVD/VCR Dual Player
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
124 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
