Question about LG Shine KE970 Cellular Phone
Charger cant open socket to charge fone
  • 1 more comment
  • sweeet Dec 08, 2007
    i just cant open bit to charge, help
    take it LG is not as good as it looks
    gonni help
Its the same one you put your head phones in. Use the slot to open it. It opens down wards after you flip it.
Posted on Dec 09, 2007
Htc not charging
Hello Dear Friend:"::"
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 22, 2013 | HTC Cell Phones
I just dont know :/
That should not be too difficult to find out. Plug the phone in the charger and the charger to the wall socket. The phone should say Charging. Even if your particular phone does not say charging, leave the devices connected to the charger. After a few hours, unplug th phone and turn it on. If it does not stay on there is no charge. If it stays on, use your phone and see how long the charge lasts. If it lasts the same amount of time as it used to, then the charging occurs normally. If the charge does not hold, then there is incomplete charging or no charging at all.
Jan 14, 2012 | Computers & Internet
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
I have a problem with my mobile nokia n81 8gb charging problems. When i put the charger in my mobile it says charging but the battery doesnt go up and down like it use too also when i press the charger...
from your explanation, the problem is from your charger, it is either its making partial contact somewhere or if you have purchased another charger asides the one which originally came with the fone, then it might have been substandard. try using a different charger on your fone or/and your charger on a different fone, this should help you confirm where the problem is from
Jan 01, 2011 | Cell Phones
The batteries in my studio 3100 no longer seem to be charging on one phone only.i cannot seem to buy replacements anywhere.the batteryis unitech 500mAh 1.2 volt.
Try to get a new battery with a different charger velocity, Go to amazon or ebay if it cant be found locally.
-Hope i was of use. But before you try this find someone with this same fone and try to charge it with your charger and if it doesnt charge you need a new charger. Hope i helped
Apr 30, 2010 | Lands Phones
Switch on!!!!
PLUG IN CHARGER AND SEE IF IT STARTS TO CHARGE IF IT DUSE NOT GET NEW CHARGER IF IT DUSE START TO CHARGE TRY TO TURN ON AS IT IS CHAGRIN IT SHOULD COM ON MAKE SHORE THAT THE BATTERY IS HOLDING A CHARGE
Jan 10, 2009 | Nokia 3110 Cellular Phone
Won't Charge- Is there anything I can do?
well i dont have any long term ansa but here is a short term one while you find a new charger.
Take the charger and dismantle the end that plugs into fone. you should have 2 wires a black & white or black & red. Leave the blobs of solder on the end of the wires as this helps. Leave the wall socket end of charger in tact.
Take your battery out of fone. As with a normal battery you will see a (+) and (-) sign on it. Attach the black or darkest wire to the negative (-) metal square on the battery and the white or lightest wire (maybe red) to the positive (+) metal square on the battery (after trial & error i found a clothes peg to be the best form of attaching it). Leave attached for 15 minutes and this will give you around an hours usage when you put the battery back in the fone. If you leave it overnight then it will be on all day.
Basically you are making the circuit without the fone which bypasses your pin problem. Any charger will work with any fone as the charging components are in the wall end. Just make sure the voltage is compatible ie, 5v fone charger replacing 5v charger etc. Although majority of chargers are 5v.
I know this works cos i did it to mine last nite as i needed to ansa my emails. Really simple but a little drastic like i said but if the pin connector is broke anyway wot you got to lose?? I am a girl so if i can do it anyone can lol!!
Only drawback is you cant use the fone while it is charging unless you have 2 batteries and you use one while the other charges which is what i am doing. In fact i might not buy a new charger lol, i dont need one now ive found this method works.
Happy charging!! Hope this helps! Gail-michelle
Jun 14, 2008 | LG enV VX9900 Cellular Phone
Nokia 6233 charging problem
ok... you can dis assemble your fone at u'r own risk...if you have warranty and when you open u'r fone it will be void.. ok here's the basic.. open it.. look for the contacts of the charger and clean it with the thinner on both pin and board and lift the pins a bit... if still the same you cannot fix it by urself.. bring it to the service center...you have capacitors or uem fault...
Apr 19, 2008 | Nokia 6233 Cellular Phone
LG Shine KE970 Cellular Phone Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
