Question about Whirlpool Refrigerators
My refrig mod ed5shaxmq00 seril sp4046445 type 25ssa - is not working properly the freezer part is working great but the regrigerator is not keeping cool...what do i do?
jumptrout51
  • 3361 Answers
SOURCE: Regrigerator isn't cooling - freezer is fine....
Make sure there is not a ice build up in the back wall of the freezer.
If so, you have a defrost issue.
Make sure the freezer fan is blowing.
If so, you have a thermistor issue.
Posted on Feb 22, 2009
  • 22 Answers
SOURCE: Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Posted on May 04, 2009
  • 532 Answers
SOURCE: GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
Posted on May 09, 2009
zr800o1le
  • 19 Answers
SOURCE: Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
Posted on May 12, 2009
co7196
  • 3433 Answers
SOURCE: Refrig constantly runs and is only semi cool, same w/the freezer. Left out in a cool room in the winter and stop running when it was cold. Started refrig back up and now runs constantly w/out cooling
Let freezer get down in temp and fridge should start chillg.Good luck
Posted on Jun 03, 2009
My refrig and freezer wasn't working good, i replaced the heater that goes underneath the coils. now my problem is the freezer is on 0 degrees and the refrig is on 60 degrees, i noticed the flap that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
Our 2 door water dispensor not working. ice coming through o.k.
I followed a suggestion from one of your customers and it worked!
JKP
Jan 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Mod#RS25AGXN002 FRIG NOT COOLING FREEZER NOT FREEZING
the return air ducts are iced up and need defrosting, empty the fridge and freezer and unplug for 3to 4 hours with the doors open
Oct 03, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer works great, fridge not cooling Whirlpool 25ssa model ED5NHEXQ00
is it a bottom freezer and top refridgerator then the gas level are low in the system
Aug 13, 2009 | Refrigerators
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
10 year old refrig cools only if freezer temperature is on maxium
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 18, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My refrige leaks water on the floor from the freezer side on the left. I turned the water off and disconnected the water line. Still once or twice a week the refrige leaks water on the floor.
Sounds like ice build up on the freezer coils. Disconecting the water line doesn't stop regrigerant from flowing through the coils since they are still working. Easiest way would be a hair dryer to melt the built up frozen consensation. After you should see no water on the floor and you can turn the water back on (i assume the water is for your ice water and ice cube tray).
Apr 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Kenmore Refrigerator not that cold.
How full is the frezzer compartment with product?
Sep 15, 2008 | Refrigerators
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Ge side by side regrigerator
You'll find that the defrost heater is the problem most of the time.
Dec 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
