Will only fill & empty
When i put the machine on, thats all it does is fill and then empty as if thats all it has to do.The drum does not move at all but the belt is fine because i took the back off to check.Please Please any advice would be welcome.
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Bowl will not turn or spin in any cycle the machine fills and emptys but the bowl just doesn't agitate
Sounds like either the belt has snapped from drum to motor or the motor has gone its easy to fix just remove the rear panel check to see if the belts snapped put new one on there should be a nut that tightens the belt up on the motor psrt put belt around drum part and motor and move the motor to tighten yhe belt up
Jul 27, 2017 | Washing Machines
How can we fix the vitiation, noise, and movement on a front loader that was just moved to another home?
These units spin at a high RPM. With just a few clothes, especially jeans and sweat items, the drum is off balance and therefore will have the above symptoms. These newer units weren't designed to run just a few items. It's a full load or nothing. It's an energy conservation thing.
Sep 26, 2014 | Kenmore Elite 45986 Front Load Washer
Filling bobbin
is it still under warrenty where you can take it back?
Apr 09, 2012 | Singer 1507
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Jul 28, 2009 | Washing Machines
WFC 2260 - Machine Fills and empties, but drum doesn't rotate
You probably need to replace the brushes in the motor.
Remove rear panel, remove belt from drum, undo 2 screws securing motor, unplug lead to motor, lever motor back with a screw driver, keeping hold of it, and remove motor.
You will find the brushes located at the opposite end to the motor pulley.
Please leave a fixya rating for my proposed solution.
Thankyou.
Feb 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Drum wont spin
Check brushes in motor, replace if worn
Oct 01, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
