Question about Friedrich CP12C10 Wall/Window Air Conditioner
White dust After not using the air conditioner for a month, I turned it on and it is blowing a medium-fine white dust into the room. I've cleaned the filter and vacuumed the machine, but the problem continues. Is it dangerous to breathe? What can be done?
  • 615 Answers
If the unti working good and cooling then change the filter it may be too old.
Posted on Sep 08, 2009
My new Hoover Wet & Dry Vacuum Cleaner-1800w sucks dust from the carpet but it also blow abt 50% of the dust out into the room. Everything is covered in a layer of white dust. The hose is fitted 100%
It seems it must be blowing out from somewhere. Try to figure out where by feeling for air blowing to try to determine where it's coming from and why.
Mar 16, 2018 | Hoover Vacuums
Why is my air conditioner blowing white smoke?
Smoke or frost? More than likely frost make sure the air filter is clean and evaporator coil is clean this is a sign of low air flow across evap coil or turn fan speed up.
Aug 06, 2014 | Dometic Rooftop RV Air Conditioner
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
Hello. I'm having a little problem... I have an White-Westinghouse split-type air conditioner (model WSA12PTGMA). The problem is i've lost the user guide manual... and now (after a long period of...
The unit is low on refrigerant and the freeze sensor is shutting the unit down... if you reset it is will wait for the 15-20min to time out before it shuts down again...
heatman101
Jun 20, 2011 | Electrolux Heating & Cooling
White smoke coming from vent in room air conditioner
it sounds like it was humid which is normal for the cool air to mist, it will happen in your automobile ,also
Jul 24, 2010 | Airtemp B3Q06F2A Air Conditioner
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
No longer blows cold air and the unit is only 15 months old
First please clean the air filter and ensure that there is no dust settled on the filter which could chock the circulation of air.
To throw cool air the unit got to **** the air from the room and in case the air filter is blocked with dust then there will be no cooling at all.
Please ensure the thermostat knob is turned to the desired cooling level and try running the unit.
Ensure there is no escape route for the cool breeze.
Minimize the frequency of the door or window opening in the area to retain cooling efficiency.
I am sure your unit will work on taking the above precautions before operating it.
Jul 08, 2009 | Haier CPRD12XH7 Air Conditioner
Laptop CPU
*There can be alot of dust inside the fan ducts and it has to blow harder to get the air flowing. I recommend you clean the cooling system.
Compressed air + vacuum cleaner
blow the compressed air from the other end while the laptop is turned off and have the vacuum on low / medium in the other end sucking the dust so it wont fly all over the room.
also another way is to take the laptop apart and clean the parts.
May 09, 2008 | IBM ThinkPad T60 Notebook
White dust coming out of humidifier
A concern is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck
Apr 05, 2008 | Bionaire BU4000-UC Humidifier
Friedrich CP12C10 Wall/Window Air Conditioner Logo
275 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
