Question about Panasonic Televison & Video
When the screen is displaying white or a light color, brown patches are evident on the screen. I've cleaned the outside of the screen so I know it's not on the outside. How can I remedy this?
  • 178 Answers
The problem is with the panel, it needs replaced.
If the set is still in warranty get a tech out there to check it out.
It is cost prohibitive to repair if it is out of warranty.
Posted on Sep 05, 2009
A brown headed snake with light colored patches outlined in black. One on back of the head as the rest of body
Click the link and when ready, click images.
http://lmgtfy.com/?q=A+brown+headed+snake+with+light+colored+patches+outlined+in+black
Jul 14, 2014 | Televison & Video
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
A white screen is in the middle of the screen and blocking everything the laptop was cold when I turned it on now it is changing colors
white screen indicate the patch on the display possibly either display is physically or internally damaged....if its a software fault try reinstalling the video drivers...it may help else u can contact the manufacturer for service
Feb 13, 2012 | Toshiba Computers & Internet
Wall Plate teminals have the colors of Green, Red, Black, Yellow, White, Blue, Brown and Tan. Cable has the Colors White/Blue, Blue/White, White/Orange, Orange/White, White/Green, Green/White,...
see the table on this link:
http://www.server-servers.com/ge-cat5-network-wall-plate-straight-through-cable-setup/
GE Network Wall Plate Cat5 Ethernet Cable 1 Blue 2 Orange 3 Black 4 Red 5 Green 6 Yellow 7 Brown 8 White White / Orange Orange White / Green Blue White / Blue Green White / Brown Brown
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Computers & Internet
Ok i am trying to change the raido in the car. i need to know what all the wires in the back are. which color goes to what. they are not taged and i am not sure, can you help me.
Is the plug cut or somthing? and are you installing an aftermarket radio?
if so you have to read the colors on the manual for the radio then match them up with the following
Constant 12V+ Green/Purple Switched 12V+ Yellow/Black Ground Black/Light Green Illumination Green Dimmer n/a Antenna Trigger n/a Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) White/Light Green Right Front (-) Dark Green/Orange Rear Speakers 5" x 7" Side Panels Left Rear (+) Light Brown/White Left Rear (-) Light Brown/Yellow Right Rear (+) Light Brown/Green Right Rear (-) Brown/Pink
Apr 04, 2010 | 1998 Ford Windstar
On bright white the screen colour is pink. On green, such as a football pitch, it has reddy brown patches. There is also ghosting of previous screens which hang around for quite some time
hi it looks to me the screen is on the way out or ur set need color addustment from a service centre call phillips and tell them about ur problem
when i say call phillips i mean call the service centre u will find it in ur phone book
Nov 28, 2009 | Philips 50PF9630A 50 in. Plasma Television
Adding new extension to Nortel Norstar Meridian Phone System
you should have a panel designated for the system phones only and a panel for your wall jacks.
you only need to take two wires from the designated phone extension you want to activate to the wall jack you need activated. If you have a RJ 45 panel all you need to do is patch one end to the system phone port and the other end to the wall jack port make sure on the back side of the panel that the wires are punched down. The thin wires will need to be punched down with a special punch tool that you can purchase from Home depot or Lowes depending on what kind of panel it is. White/Blue,Blue/White,White/Org.Org/White.White Green/Grn/White.White/Brown.Brown/White.Solid White with violet color stripe.Solid Violet with white stripe is the color code in which to punch down for each cable. What city are you in may i ask?
May 29, 2009 | Ics Norstar MICS (0x32) Modular Cartridges...
1995 stony creek popup by fleetwood/coleman I need to know whateach of the colored wires in the six prong trailer plug go to
Hi Sk,
Horse, stock or utility trailers:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Ground should be 10ga.
Others 14 ga
That ought to do it,
Mike
Aug 17, 2008 | Scosche Industries EFX Amplifier Wiring...
Televison & Video Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
