Before ac kicks on a loud clicking noise starts could be 2 to 8 clicks just be fore it starts.
  • 55 Answers
If the noise is coming from the outdoor unit you probably have a bad set of contactors. you may just have ants or bugs in them open the electrical panel on the unit and look at the piece where the wires coming into the unit from the wall connect look for ants in and around this component. they probably just need to be replaced. only other problem could be bad or low voltage coming from indoor system or bad wires that were hit with at weed eater or chewed by animal or just skind and shorting out.
Posted on Sep 13, 2009
Ac makes clicking sound when switched to max
You just go to the link I attached I'm sure you will get the solution of your problem
KIA Sorento 4cyl 2 4L 2011 OEM Factory SHOP Service repair manual FSM
Jul 11, 2016 | 2011 Kia Sorento 2.5
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
My sym symply 2 125 broke down this morning.it was making aloud ticking noise and then completely shut down.the electric start just makes a click now when pressed and the kick start is jammed. Only the...
That loud clicking was most likely a rod bearing going out. The bike quit and locked up as a result. This is serious and expansive. Sorry
May 07, 2014 | Cars & Trucks
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
Jeep cherokee when in drive, front right under the hood clicks and the RPM's kick for about 2 seconds this cycles about every ten seconds.
its hard to say is your ac compressor kicking on i need more details on where the clicking is coming from ac compressor is a guess due to it raising rpms when turned on and makes clicking noise turning on and off
Dec 05, 2012 | Cars & Trucks
Loud humming noise from under my Tahoe 2 WD
Is it closer to the back of the vehicle or the front?Possibly the fuel pump. Try opening the gas tank and stick your ear close to the intake of the tank while someone turns the key.
Aug 02, 2012 | Chevrolet Tahoe Cars & Trucks
How to change a starter motor on a 2000 Buell CycloneM2?
The loud Click click click isn't because the starter is bad it is because your battery doesn't have enough power to kick it over. Change your battery. The click will stop. Harley starters either spin without making any click noises or don't make any noise when they go bad.
May 02, 2012 | 2000 Buell M2 Cyclone
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
