Question about Pentair Minimax NT Heater
Once heater canister fills with water it pours out of the upper white capped valve onto the cannister and into theunit. The longer it is left on, the more water is pumped out
    Champion:
  • 246 Answers
Waooo is gues su have a leak if the heat exchanger is leaking this may be due to a low PH level on the water? if the leak is at the fitting than replace the fittins
Posted on Sep 14, 2009
How to flush coolant from a 2003 holden vectra zc
Disconnect upper and lower radiator hoses while vehicle running. Insert water hose on upper hose and let it run water until you no longer see coolant coming out. Remember to have heaters running to also clean heater core.
Once clear water comes out of lower hose, turn vehicle off and re-attach both hoses. Fill with proper coolant and run vehicle with heaters on. Take for a drive to remove any air from system. Then top off with coolant.
Dec 07, 2016 | Cars & Trucks
Engine lite on 2002 4.0 new gas cap
V A new gas cap dose not always solve the problem with the EVAP system .
And understand the concept of the system is unsound to begin with .
What its supposed to do it store fuel vapor in a sealed system in a charcoal filled canister at the rear near the fuel tank .It has a vent valve from the tank to the canister most likely problem .The vent valve has a filter air needs to get in so the tank can vent into the canister but vapor can't get out .Its an electrically controlled solenoid that opens in conjunction with the canister purge solenoid located on the intake manifold .
When the engine rpms reach a high enough speed the purge valve is supposed to open and burn the fuel.
With cheap materials from China the fuel system rusts out the tank the lines all of the seals in a few years add road salt you are left with nothing except a government mandate drafted by fools .
The last time I filled up my tank hundreds of times more fuel vapor went in to the upper atmosphere then my vehicle with the evap not working in a year .
Jul 06, 2016 | Jeep 2002 Grand Cherokee LAREDO
Honda aspencade has fuel pouring out of purge control valve
Replace the valve and check that the fuel tank is not continually being over filled . ON some cars the tank can only be filled to when the nozzle cuts off automatically and filling right to the filler cap allows fuel into the canister and floods the system. Run fault codes to check for any other system faults.
Jul 02, 2014 | Cars & Trucks
How do you de-winterize 28DSBH
Connect the trailer to the city water supply, turn on the water and open each faucet until clean clear water is present. Don't forget the toilet and outside shower if equipped. Next reinstall the anode rod (suburban) or drain plug (atwood) into the water heater. Go to the back side of the water heater and close the valve on the pipe that connects the cold (bottom line into water heater) and hot (upper line out of the water heater) and then open the bottom cold water line valve and, if equipped, the upper hot water valve. This will fill the water heater. Open the hot water valve at the kitchen faucet. When the water flow is steady the water heater is full and ready for use. If the unit is equipped with a water filer, after all is flushed out, turn the water off and remove the filter housing. Install a new filter and re-secure the housing and turn the water back on. If you are using the fresh water pump, it is possible that the winterizing valve for the pump was left open. If so, close that valve which will divert the pump back to drawing from the tank.
May 08, 2014 | Jayco 2013 White Hawk Ultra Lite 28DSBH
Runs good engine lt on code p0455
A loose gas cap or bad gas cap can cause this ,or filling gas tank while it running .or it could be a small leak in the evap system
Apr 21, 2014 | 2003 Jeep Wrangler
2002 isuzu rodeo cylinder head torque lbs. for 2.2
Print
Removal & Installation
2.2L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the cooling system.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following: Negative battery cableIntake Air Temperature (IAT) sensor connectorPositive Crankcase Ventilation (PCV) valve and hoseAir intake assemblyUpper radiator hoseAccessory drive beltExhaust front pipeAlternator and bracketsCrankshaft Position (CKP) sensor connectorKnock sensor connectorHeater hosesWater bypass hoseFuel linesEvaporative Emissions (EVAP) valve connectorCanister hoseIntake manifoldEngine wiring harness connectors at left rear of the engine compartmentPower steering pump pressure switch connectorFront coverSpark plugs and wiresCamshaft Position (CMP) sensorValve coverTiming belt. Refer to the Timing Belt unit repair section.Timing belt idler pulleysTiming belt rear coverOil pressure switch connectorCamshaftsCylinder head. Remove the bolts in reverse of the tightening sequence.
    Negative battery cable Intake Air Temperature (IAT) sensor connector Positive Crankcase Ventilation (PCV) valve and hose Air intake assembly Upper radiator hose Accessory drive belt Exhaust front pipe Alternator and brackets Crankshaft Position (CKP) sensor connector Knock sensor connector Heater hoses Water bypass hose Fuel lines Evaporative Emissions (EVAP) valve connector Canister hose Intake manifold Engine wiring harness connectors at left rear of the engine compartment Power steering pump pressure switch connector Front cover Spark plugs and wires Camshaft Position (CMP) sensor Valve cover Timing belt. Refer to the Timing Belt unit repair section. Timing belt idler pulleys Timing belt rear cover Oil pressure switch connector Camshafts Cylinder head. Remove the bolts in reverse of the tightening sequence.
To install:
Fig. Cylinder head torque sequence-2.2L (VIN D) engine
NOTE Use new cylinder head bolts for assembly.
  1. Install the cylinder head with a new gasket. Tighten the bolts in sequence as follows: Step 1: 18 ft. lbs. (25 Nm)Step 2: Plus 90 degreesStep 3: Plus 90 degreesStep 4: Plus 90 degrees
    1. Step 1: 18 ft. lbs. (25 Nm)
    2. Step 2: Plus 90 degrees
    3. Step 3: Plus 90 degrees
    4. Step 4: Plus 90 degrees
  2. Install or connect the following: CamshaftsOil pressure switch connectorTiming belt rear coverTiming belt idler pulleys. Tighten the bolts to 18 ft. lbs. (25 Nm).Timing beltValve coverCMP sensorSpark plugs and wiresFront coverPower steering pump pressure switch connectorEngine wiring harness connectors at left rear of the engine compartmentIntake manifoldCanister hoseEVAP valve connectorFuel linesWater bypass hoseHeater hosesKnock sensor connectorCKP sensor connectorAlternator and bracketsExhaust front pipeAccessory drive beltUpper radiator hoseAir intake assemblyPCV valve and hoseIAT sensor connectorNegative battery cable
    Camshafts Oil pressure switch connector Timing belt rear cover Timing belt idler pulleys. Tighten the bolts to 18 ft. lbs. (25 Nm). Timing belt Valve cover CMP sensor Spark plugs and wires Front cover Power steering pump pressure switch connector Engine wiring harness connectors at left rear of the engine compartment Intake manifold Canister hose EVAP valve connector Fuel lines Water bypass hose Heater hoses Knock sensor connector CKP sensor connector Alternator and brackets Exhaust front pipe Accessory drive belt Upper radiator hose Air intake assembly PCV valve and hose IAT sensor connector Negative battery cable
  3. Fill the cooling system.
  4. Start the engine and check for leaks.
  1. Before servicing the vehicle, refer to the Precautions Section.
    Negative battery cable Intake Air Temperature (IAT) sensor connector Positive Crankcase Ventilation (PCV) valve and hose Air intake assembly Upper radiator hose Accessory drive belt Exhaust front pipe Alternator and brackets Crankshaft Position (CKP) sensor connector Knock sensor connector Heater hoses Water bypass hose Fuel lines Evaporative Emissions (EVAP) valve connector Canister hose Intake manifold Engine wiring harness connectors at left rear of the engine compartment Power steering pump pressure switch connector Front cover Spark plugs and wires Camshaft Position (CMP) sensor Valve cover Timing belt. Refer to the Timing Belt procedure. Timing belt idler pulleys Timing belt rear cover Oil pressure switch connector Camshafts Cylinder head. Remove the bolts in reverse of the tightening sequence.
To install:
May 26, 2012 | Isuzu Rodeo Cars & Trucks
DOES WATER IN GO ON TOP OR BOTTOM OF HEATER
1) Low-boy water heater, cold water connects to lower inlet pipe and hot to upper outlet pipe.
Cold enters bottom of heater and then hot water rises to top where it leaves tank.
http://waterheatertimer.org/images/20-gal-heater.jpg
2) With larger water heaters both hot and cold connections are on top of tank, but the cold water goes to the bottom through the dip tube.
http://waterheatertimer.org/Water-heater-dip-tube.html
If pipes are reversed, the water heater will not work.
Jun 10, 2011 | Reliance & Lowboy& Electric Water Heater
1993 jeep grand cherokee havc code 06
Chrysler & Jeep Cooling System & HVAC Service: Every car make has its quirks, and Chrysler and Jeep vehicles are no exception. In researching this article, we found several examples of heater problems in these vehicles that seem to be fairly common.
On 2001 and 2002 Sebring Sedan, Sebring Convertible and Stratus Sedan, plus 1993 to 2002 Chrysler Concorde, LHS, New Yorker and 300M, Eagle Vision and Dodge Intrepid models with V6 engines, customers may complain their engine is overheating, or the heater is putting out little or no heat.
Chrysler Technical Service Bulletin 07-002-02 says the problem can be caused by a low coolant level in the cooling system. On these vehicles, air trapped inside the cooling system can displace coolant when the system is refilled. The radiator and coolant reservoir may appear to be full, but there still may be air inside the heater core and heater hoses. This will create a low coolant level that may lead to overheating and low heater output. The bulletin provides a special fill procedure to eliminate the trapped air so the cooling system can be completely filled.
The procedure goes as follows:
1. Obtain Chrysler special tool 8195 (Cooling System Filling Aid). The tool looks like a funnel and attaches onto the filler neck (just as a regular pressure cap does). But it also has a hose clip.
2. Attach the filling aid tool to the cooling system filler neck. Use the clip to pinch off the overflow hose attached to the fill neck. Attach a 4-6' long 1/4" ID clear hose to the bleed valve. Put the end of the hose into a clean container (to prevent coolant from spilling onto the accessory drive belts).
3. Open the cooling system air bleed valve before any coolant is added. If you do not do this, air can remain trapped inside the system and you won't get all the air out. On 1998 and later models with 2.7L engine, the valve is located on the water outlet connector at the front of the engine. On 3.2L and 3.5L engines, the valve is located on the lower intake manifold, left of center under the upper intake manifold. On 1993-'97 models with 3.3L and 3.5L engines, the valve is on the thermostat housing.
4. Pour a 50/50 mixture of coolant and water into the large side of the filling aid funnel. Use distilled, deionized or reverse-osmosis purified water, not ordinary tap water, which may contain salt or minerals that could contaminate the coolant.
5. Slowly fill the cooling system through the large side of the filling aid. Watch the hose connected to the bleed valve. When a steady stream of coolant comes out of the hose, close the bleed valve and continue filling to the top of the filling aid.
6. On 1993-'97 models, place a small, clean container below the end of the overflow hose. Then remove the clip from the overflow hose. Any excess coolant in the filling aid will now drain into the overflow section of the coolant bottle or into the container.
7. On 1993-'97 models, remove the reservoir and recycle the excess coolant.
8. Remove the filling aid from the fill neck. Make sure the filler neck and cap are clean, then replace the pressure cap on the coolant bottle.
Note: 1998 and later coolant bottles have two chambers. Coolant will normally only be in the inboard (smaller) of the two. The outboard chamber is only to recover coolant in the event of an overheat and should normally be empty - except for the coolant drained from the filling aid. This coolant will be drawn back into the pressurized side of the cooling system over time.
Hope helps.
Jan 12, 2011 | 1993 Jeep Grand Cherokee
Overheating
You have an air lock in the cooling system.
Do this: pull upper radiator hose off the radiator leaving it connected to the block, pour coolant into hose until filled ( you might have to do it to the radiator also). Once filled reconnected hose back to the radiator, then fill resevior to proper level. Start car turn heater on full. Let car run with cap off resevior until it starts pulling coolant in. Once warmed up shut car off let cool. Check fluid level again.
Jun 18, 2009 | 1998 Ford Taurus
Having trouble pumping gas into 2005 hyundai elantra
You have a blocked or restricted evaporative cannister or vent valve or both. When you fill the tank with gas, the air is expelled through a line attatched to the emissions cannister and then through another line to the vent valve. If these are restricted or damaged, this could cause your symptoms. Usually you can still fill the tank very slowly though. Usually, the canister ges saturated from gas from overfilling (topping off).
The fix is to replace the EVAP canister.
Jan 16, 2009 | Hyundai Motor 2002 Elantra
Pentair Minimax NT Heater Logo
121 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
