My portable AC make a noise after a few minutes of star working and then the air wasn't cold
  • 615 Answers
The fan not working good and you need to check it first
Posted on Sep 08, 2009
Portable ac Danby Premiere DPA110CB5BP spitting water while it fans.
If you are referring to the unit doing this on the outside of the structure, this is normal. the "Hamster Wheel" is designed to carry a small amount of water and create a light amount of water to go onto the condenser to help with the evaporation and cooling process. If this is on the inside of the structure, the unit may not be level or another issue causing improper drainage.
Aug 01, 2017 | Danby Heating & Cooling
2000 jeep cherokee AC compressor clutch makes 2 rattling noises when I first start the engine for the day. It only started doing this after I recharged the AC with r134a because the AC wasn't blowing...
Does it make the noise even if the ac is switched off ? Its possible you have too much freon in the system, but the compressor should not be involved if it is turned off.
Jul 03, 2013 | Cars & Trucks
After a couple hours of use Ac unit does not blow out cold air
1 make sure any air or fan vent is clear of lint and dust
2 move the ac further away from wall
3 possible compressor temp sensor gone bad requiring a tech
hope this helps
Sep 15, 2012 | Continental Electric Portable Air...
I noticed my ac in my 2004 Corolla with 138,000 miles wasn't blowing as cold in recent months. I've never had the AC serviced in the 8 years I've owned it. So I used one of those 12 ounce self...
If this was happening to me.... I'd goto an airconditioning re-gas centre and get them to check for gas leaks. In my old commodore the Evaporator Core was leaking and causing some of the issues you have mentioned.
Aug 04, 2011 | 2004 Toyota Corolla
AC will blow cold air for a few minutes then start blowing hot air, cut the engine and start it again and blow cold air for a few minutes then start blowing hot air again. Just filled up the freon and the...
you have moisture in the system this causes your expancion valve to freeze up an stop working, thats why it works for sort time and when it de-freezes stars working again. you need to do a EVAC & RECHARGE with a good AC service equipment, specially attention to pull vacumm por at least 20minutes so you get all moisture out of the system.
Good luck
Jun 05, 2011 | 2002 Hyundai Santa Fe
My air conditioner is putting out cold air for a few minutes then it's warm for 5 minutes and then it's getting cold again? I had the compressor changed by a mechanic who wasn;t sure how much freon it...
OK, the requirement of Freon is 2 cans...as for the Cold/Hot problem, a little info first; the PCM controls the AC clutch (adjusts the IAC, Idle Air Control valve to speed up the idle when turning on the AC unit, and slows down the idle after turning off the AC unit), also the PCM controls the relay that cycles the AC clutch. My experience has been that the relay is "going South". This bad boy is in the fuse block in the engine compartment by the Air Filter box. The relay is an inexpensive item, and if you live where the AC unit is used frequently, I would recommend it being replaced every 3-5 years. Be sure to check with the mechanic to make sure he properly recharged the system, and if so, try these ideas.
Jan 18, 2010 | 1996 Saturn SL
A/C air sometimes cold, sometimes not on VW Beetle 2001 Turbo
AC will not work with temps are cold even when it is turned on. The air is colder cause the temp is colder. The AC cycles in hot weather because the AC charge is low and needs recharging. You will know this if you open the hood run the AC and you will hear the clicking sound of the AC compressor magnetic clutch. You can recharge it easily buy buying a compatible can of refrigerant. I suggest buying the kit with the gage so you don't overcharge the system which will cause freeze ups
Jul 03, 2009 | 2001 Volkswagen Beetle
2004 Mazda6 AC blowing warm air
too much freon is the same as not enough freon
Have an 04 mazda6 as well, AC seems to be the cars weakness. It takes 15-20 minutes till my car is ina driveable condition (Phoenix, AZ)
Take it in for a tune up, but I doubt the AC will be any better
Jun 19, 2009 | 2004 Mazda 6
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
