Question about Hayward H-series Electronic Gas Pool Heater H300
Do I need to take the front cover off of the heater in order to find the pilot? And will there be a switch I need to turn while relighting it?
    Champion:
  • 246 Answers
Ok do you have a electrical cord conected to the heater if yes than you have a electronic heater and you do not have to turn on the pilot. if not than yes you must open the pilot ang ligther just as water heater for you house.
Posted on Sep 14, 2009
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
Light pilot light
Many heaters have pilot flames can be relighted with a match or push button operation. Many employ safeguards to prevent unburnt fuel from accumulating in the space or allowing an unstable pilot flame from "proving".
Most appliances have instructions printed or embossed on or near the pilot, gas valve or protective cover. It is very important to closely follow these instructions for your safety and that of others in the area. If you are unable to locate the instructions or follow them and relight the pilot, you should contact the gas company for assistance. This can be in indication of an issue with fuel, thermocouple, gas valve, etc., and would require a service person to correct.
I have included a link to a video to light a gas heater - yours may be the same or similar:
How To Light The Pilot Light On Gas Heater
Feb 23, 2015 | Heating & Cooling
I have taken the outer case off my alpha c23 combi and need to try relight the pilot. There is another cover on the inside that covers where the pilot light is. Help anyone please no money to get someone...
The inner cover has to be removed to relight the pilot. The cover can be awkward to remove but it should be a sliding fit without hardware removal necessary.
Jan 04, 2015 | Water Heaters
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
How do i relight my standing wall heater light, where is it?
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Nov 12, 2010 | Montgomery Ward (223600UP) Heater
Heater won't relight or turn back on after the thermostat turns
Verify that your pilot is staying on if you have a pilot.
Some may have electronic ignition.
Oct 01, 2009 | Williams 1403622 Gas Compact Heater
Pool heater won't stay lit
check gas pressure might be running out of pressure gas meter might be too small and heater could be overheating
Jun 03, 2009 | Teledyne Laars Pool & Spa
Potterton FF80 boiler, pilot light has gone out how do we relight
if you can see where the pilot is you can turn the gas in the on position and use a long candle lighter and manualy light it but be careful doinng so
Nov 12, 2008 | Stiebel Eltron DHC Instant Tankless...
Hayward H-series Electronic Gas Pool Heater H300 Logo
121 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
