Question about HTC Snap S522 Cell Phone
My snap won't hold a ringtone, it reverts back to vibrate. how can I fix this?
How do I get a ringtone instead of vibration on my LG530G cellphone?
try going into settings and change the method from vibration back to ring tone
Sep 06, 2015 | LG 5350 37V 1550mAh Extended Life Liion...
Recently download 'fun for mobile' for free ringtones. The ringtone downloads to files, not to my ringtones
Try installing Astro File Manager and then there should be an option to push menu and then Set as Ringtone.
Jul 21, 2014 | Motorola Mobility XT907 DROID RAZR M...
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
Droid X phone won't ring for incoming calls.
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Jul 29, 2010 | Google Android
I can't change my ringtone. It's stuck on vibrate
press the # so that you can change from vibrate to tone
Apr 09, 2010 | HTC Snap S522 Cell Phone
How to change from ringtone to vibrate and back
Press and hold the * key to switch to turn "Vibrating mode on." Press and hold * again to turn "Vibrating mode off."
Dec 23, 2009 | LG CU515 Cellular Phone
Ringtone Problem!
hi there.
ur problem might be referd to a damaged or corrupted phons Firmware.
or just a miss set up
try to give ur phone a Format this is might be helpfull but u need to back up messges/contacs/photos/viedos.
to format press:
* plus # plus 3 plus green call key plus POWER
phone shud be off
- or u can try first the *#7370# then 12345 this is restore the CP to factory defaults
that was a tips i guess hehe..
any way rate this post if u can its easy click on fix ya
Aug 25, 2008 | Nokia 6500 Slide Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Phone will not ring
Thanks, The orange dot on my phone was showing as well. That fixed the problem.
Jan 21, 2008 | Apple iPhone Smartphone
No ringtone - it only vibrates
Perhaps your volume is all the way down.Or on whats called "etiquette mode" Turn your volume all the way up, or if that doesn't work, press and hold your star key until you hear a chime.
Dec 26, 2007 | Audiovox 8910 Cellular Phone
HTC Snap S522 Cell Phone Logo
367 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
