Question about Bachmann Railroad Ho Scale Train Set The Comet Train
I have a Bachmann electric train and the engine seems to be frozen. I have verified their is power to the tracks. What do I do?
  • 2,976 Answers
An electric train is simply a DC motor and a gearbox. Take the body off and check the motor for continuity. If it checks okay, carefully, tourn the motor. You might have a broken gear in the gearbox. A good hobby shop should be able to find parts or, you can get them online.
Posted on Sep 05, 2009
    New Friend:
  • 107 Answers
Hey there, Wyre Associates Electrical Engineer Training was established in the North West of England in 2005 by David Wyre, an electrical engineer and respected consultant in the electrical engineering industry for over 35 years click and see!
Posted on Sep 03, 2016
Thomas only runs on power track
PDF]EZ Command instructions.qxd - Bachmann Trains
Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
[PDF]5 Amp Power Booster - Bachmann Trains
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
Jan 08, 2016 | Bachmann Ho Bachmann Thomas and Friends...
Bachmann Emily
check all track connectors(squeeze lose ones with a needle nosed pliers..check wire from transformer to the track..and during assembly, the track gets any dust on it, the wheels wont make proper contact for the engine to run..) as for the locomotive.. sometimes you can clean the motor brush comutator with a simple pencils' erasure by rotating the motor armature by hand(small as it is) to clean the pickups on will better help to transferr the electric into the motor..sometimes on these track layouts, you need fine grit sandpaper to run across the top of the rails as the manufaturer puts a protective coating on these.. it wont carry power to your can also use the backside of a butterknife drug around the layout a few times with the electric off.. it helps you feel any rough spots on the track/layout..
Mar 08, 2014 | Bachmann Thomas Tank Emily's HO Train
Bachmann train
It sounds like rather than disconnecting the current the wheels are shorting the track? Does it spark a lot when the back wheels are placed on the track? If so I would suggest the insulation on the wheel axle has broken down.
Nov 16, 2013 | Crafts & Hobbies
How much does it cost
Bachmann parts catalog shows the 44871 Graduated Pier Set as a track accessory for HO track. the catalog price is $23.00But...Internet Hobbies
Shows 44871 as an N Scale 16 piece E-Z track pier set.
Their retail price is $22.00
sale price is $14.99
Follow the link to their web site & call them to check on current price and availability.
Feb 11, 2013 | Bachmann N Scale 16 Piece Pierbridge Train...
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
One of the engine wheel is rotating but other wheels seem to be stationary. The engine thus slides along for a bit and then stops. It is a ho scale model
If you are the original owner,send it back to Bachmann
for repair or replacement..
Contact Bachmann Parts & Service :1- 800-356-3910
May 26, 2011 | Bachmann James The Red Engine Train Set
I just bought a Bachmann - Spectrum® Village Street Car Christmas Train Set - On30, for my window display and for some reason it only flips into reverse at the end with the car barn, but not at...
Make sure that the last track before the bumper is marked to be at the end of the trck - it will be marked on the bottom of the track and there will not be electrical connectors at one end of the track.
Nov 25, 2010 | Bachmann On30 Christmas Village Street Car...
Bachmann power pack shows a short.
Look in the tunnel and see if there are any thin bits of metal that could be shorting it out. If it is a sectional track layout, unclip the section just before the tunnel and just after. Try this to all your sections. If there is a short, your train should work until you connect the bad piece to it then all will stop. Basically a process of elimination. Also check connections to the track to see if there is a single loose wire that may be causing the problem. Another thing is getting the power pack and connect it to a single piece of track which is not connected to the layout and try the train. It could be the train shoring it out, try the train and if it works, it's got to be the track..
Dec 21, 2017 | Bachmann James The Red Engine Train Set
Bachmann HO train set not working
I realized that you can't use two left hand turnouts because they end up making a short when the come full circle!
Jan 19, 2009 | Bachmann James The Red Engine Train Set
Bachmann Railroad Ho Scale Train Set The Comet Train Logo
972 people viewed this question
Top Bachmann Crafts & Hobbies Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
