Question about Yamaha 4500 Watt Electric Start Generator - EF5200DE
Onan Marquis Indiana 5000 generator
I have a Onan Marquis Indiana 5000 generator. When I connected 240 mains to the RV I did not disconnect the plug of the genset. Although genset was not runnig at the time. There is now no 240 from the genset. Can anyone help with this problem as I can not find any information on the Onan website regarding this?
  • alison_iom Sep 05, 2009
    Thanks fredy2. Makes sense now. I'll check this out and let you know how I get on. Thanks
  • Yamaha Master
  • 5,603 Answers
You MAY have blown the rotating diodes on the rotor.
This would require servicing.
Posted on Sep 05, 2009
    Scholar:
  • 100 Answers
CHECK THE OUTPUT TERMINALS OF THE GENERATOR WITH YOU OHM METER ON X1 SCALE AND THE ENGINE NOT RUNNING. IF THERE IS A GOOD CIRCUIT, LESS THAN 5 OHMS, THEN CHECK THE ROTATING DOIDES ON THE ROTOR IF IT IS THIS DESIGN. CHECK THE REGULATOR IF IT IS THIS DESIGN.
Posted on Jan 02, 2010
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
How is the carbeurator bowl on an ONAN Marquis 7000 genset removed? I think it sat too long without Stabil and became clogged. It appears to be, maybe< pressed on as there are no visible holdong
They are generally sealed, as it affects the mixture. You can take the carb off, put on the bench and remove the shut off solenoid at the bottom of the bowl, remove black cap on main jet, remove screw, and unscrew the bowl. To set back up you will need to ideally check on a load bank, for ability to pick up full step load,
Jul 06, 2014 | Onan Marquis RV Generator 7000 Watts Gas
Onan 7000 watt generator rv starter problems
Can you be more specific than just starter problems?
Jan 17, 2013 | Onan Marquis RV Generator 7000 Watts Gas
On my 9 hp onan genset it runs fine but the 20 amp breaker on makes it shut down is there short or abad breaker
To determine if it is from the breaker use a
Tong Tester
These would indicate what current is being consumed by the load.
Jun 28, 2012 | Watts Onan Portable Generator - 5000 ,...
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Mar 07, 2010 | Watts Onan Portable Generator - 5000 ,...
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan genset generator in rv is running but no power to rv...circuit breaker has been checked and main breaker in rv has been checked still no power
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Aug 29, 2009 | Watts Onan Portable Generator - 4000 ,...
I just bought a 1999 Winnebago with an Onan 6500 genset. It only has 45 hours on it. It will run for 15 - 20 minutes with the AC on and then quits. It will restart after a few minutes and go through the...
a 10 year old genset with only 45hrs on it...sound like the carb may need replace. working with these rv units for 6+ years has taught me that you cannot clean one well enough to fix it. you will need a new carb. your local onan dealer can help. when new the warrenty makes known that 1hr per month under load will keep the carb clean and problem free. evaporating gas leaves deposits and eventualy plug fuel jets. no replacement parts are recommended. i've personaly worked on rv's with 200+ hous and no issues at all. hope this helps, good luck...
Jul 12, 2009 | Watts Onan Portable Generator - 5000 ,...
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Yamaha 4500 Watt Electric Start Generator - EF5200DE Logo
1,009 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
