Question about Mintek MDP-1760 Portable DVD Player
Mintek Portable DVD Player
I'm trying to hook this up to my TV and have the cables, but can't figure out where the white plug goes, yellow, or red... so I can't get it connected. Can you help? Thanks!
    Sergeant:
  • 217 Answers
On your TV IN .. Yellow is Video, Red is 1 Audio. White is Audio 2 this is for Stereo if Mono white is not used.Your TV then needs to be set to Aux or Imput.If no button on TV use UP-Down Chanels. Good Luck.
Posted on Sep 05, 2009
How do I hook it up to a TV so that we can watch a movie on the TV instead of the small screen
On the side there is a video out socket ( sometimes marked AV out and yellow in color ). You will have to get an interconnecting cable to link it to your TV. The back of the TV will have corresponding yellow/red/white sockets. The yellow is for video and the red/white is for left/right audio. Your player comes with this cable along with the AC adapter . bobhifi_56.jpg
Aug 16, 2011 | Mintek MDP-1770 7 in. Portable DVD Player...
How do you hook-up mintek 1770 to tv
Look for a special special connector that may or may not have come with your unit. It will be a Y connector with a plug in jack on one end and VGA (red, yellow, white) jacks on the other. Plug this end into an input on your tv.
Aug 11, 2011 | Mintek MDP-1770 7 in. Portable DVD Player...
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
Connect Portable DVD Player to TV issue
try to change the connection of the video.insert the video plug to yellow colored jack, tv and dvd.
May 17, 2009 | Mintek MDP-1020 Portable DVD Player
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Plug into Tv?
In your accessories kit that came with your DVD, you should find a cable with a red ,yellow and white RCA ends. at the other end is a 1/8 inch Tip /ring/sleeve plug. Insert the plug into the output of the DVD. Insert the yellow wire to the same color coded INPUT of your television, insert the red and white wires to the Audio input on you TV. Your DVD should be sending the signal directly to your TV. hope this helps . if it does , vote.
Dec 22, 2008 | Mintek MDP-1760 Portable DVD Player
Hooking up a dvd player
Red and white are audio cables
Yellow is video.
Your problem is that your TV has no video inputs. TVs use those red white and yellow plugs to transmit the signal via those cables.
By cable box - do you mean a digital box? You can't run it through that unforunately - those connections are only for the box itself and it only has an output.
You'll have to go either:
Buy a new TV
or get an RCA Modulator.
Dec 12, 2008 | Durabrand DWT2405 24" TV
I have the cord to hook up the portable to a tv.
Yellow-White and Red will hook to AV Input in TV and you can find same colors female pins at back of TV.
Nov 28, 2008 | Sony DVP-FX810 Portable DVD Player
Want to watch thru tv
Hi
Check and see if you have A/V out jacks on the unit. If you do, they will be yellow, red, and white.
They are called RCA jacks, and if you have them, and the TV has the same type of jacks, then you just need the cable that goes in between. The DVD player normally comes with them, but if not, you can purchase them at any Circuit City, or even Walmart.
Jan 14, 2008 | Mintek MDP-1815 Portable DVD Player
Mintek MDP-1760 Portable DVD Player Logo
184 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
