Question about Schwinn Elite Series Mens Firewire 4.0 29" Mountain Bike - Red
Can't start my schwinn 4.0 electric scooter
We bought it at an auction battery says it's fully charged but I can't figure out how to start it. I have already pulled the battery pack out to confirm that it is connected properly. The battery indicator on the left handle says it's full when the power switch is in the on position. I have tried calling the local scooter store but, they are not open on the weekends apparently. I have a very distraut birthday boy!
I do believe the model is sw-48-black
    Master:
  • 426 Answers
I suspect 1 of 3 things, The brake switch, the speed controller, or the throttle switch. I don't believe it would be the motor but there is a possibility. I am providing you some links to try and help you out. Electric Scooter and Bike Troubleshooting Repair Manual Motor Does Not Run...
http://electricscooterparts.com/manuals/ezip750ownersmanual.pdf
https://support.electricscooterparts.com/support/discussions/topics/1000044571
Schwinn 4 0 Electric Scooter Parts
Posted on Jun 10, 2017
5 Suggested Answers
SOURCE: s-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Posted on Dec 02, 2007
  • 336 Answers
SOURCE: i'm trying to figure out what kind of battery a
Your scooter uses dual 12-volt, 10-amp hour sealed recyclable lead acid battery.
You may want to open below link to see some examples of batteries suitable to your scooter.
http://www.batteriesplus.com/products/78-0/6069-Electric-Bike-Scooter-Battery/252604-Schwinn/S180-Electric-Scooter/1.aspx
Regards,
Jeep Brainy
Posted on Sep 11, 2009
Coleman37
  • 337 Answers
SOURCE: My Schwinn S-180 scooter won't charge
Check your charger with a meter and see if it is putting out the correct voltage for your scooter battery. If it is, you probably need a battery, probably so anyway after 2 years. Good luck!
Posted on Mar 16, 2010
  • 38 Answers
SOURCE: I have a schwinn electric scooter model s500. it
Hi, read my other post solution:
http://www.fixya.com/support/t2404817-schwinn_s400_no_power
Posted on Jun 29, 2010
Battery is charged, however there seems to be more power
Yes a charge fresh, fully charged battery will allow for the scooter to perform at it's peak top speed. Also fresh, fully charged battery will read more than 24v on a voltage meter and this is ok.
Aug 13, 2010 | Razor E100 Electric Scooter
Install battery
First make sure the scooter is off.
Unscrew and take off the deck
Unplug and remove the old battery pack
Put the new battery pack in and plug it in, using the same connection as the old batteries pack.
Screw the deck on and your done!
Oh, and make sure you give the battery a good charge(the full charging time). The first charge of a battery is the most important one.
May 16, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
Manual for Schwinn Mongoose z350 electric scooter
My Mongoose z350 electric scooter goes from full charge to empty in about 20 seconds. I can turn it off and back on and it shows a full charge every time. What is going on with it?
Mar 24, 2010 | Mongoose Currie Schwinn Gt Izip Scooters
I'm trying to figure out what kind of battery a schwinn electric scooter takes it is a s-180
Regards,
Jeep Brainy
Sep 11, 2009 | Transport Schwinn Rechargeable Portable ...
Schwinn S350 Scooter batteries
Schwinn batteries can be found on amazon, click here and take a look: Amazon com Schwinn S350 Scooter batteries. I hope this was helpful. Cheers
Aug 02, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Battery doesn't charge
i had the same problem so i took the battery out and pluged the moped in and it ran so i knew the battery had a prob then i took the battery out of the canvas case and it had expanded to the point were it almost leaked (exploded battery in other words)
Jul 16, 2009 | Transport Schwinn Rechargeable Portable ...
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
I charged the battery up on schwinn 180 still want go
Its likely that you just need a new battery. Batteries that are used seasonally have a shorter lifespand, especially if they are stored without being fully charged. You can find a replacement at http://www.batteryinternational.com/electric-scooter-batteries-schwinn-s180.html
Mar 08, 2009 | Transport Schwinn Rechargeable Portable ...
Does the S600 and a Missle FS schwinn scooters use same charger?
Hi you can use the charger if the Specifications match up. Output volts, Amps, Charger size, The most important is it 24 volt or 36 volt charger. Check your scooter to see what volt it runs at. Must be equal to your scooter!
Mar 03, 2009 | TitanNet PowerStar Replacement Battery for...
S-750DD
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Schwinn Elite Series Mens Firewire 4.0 29" Mountain Bike - Red Logo
578 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
