Question about Amana 3.2 cu. ft. Top-Load Washer
Agitator doesn't work on regular and permanent press cycles,
Agitator works on delicate and hand wash cycles, machine will rinse. How do we fix agitator to work on reg. and perm. press cycles?
  • Anonymous Mar 29, 2014
    When put on reg cycle it starts agitating
  • 46 Answers
Need model Number
Posted on Sep 07, 2009
  • John Timmel Nov 19, 2012
    I have similar issue with my Maytag LAT8426AA
michael, try running the wash cycle under different levels eg. normal, delicate etc without a load and see if it agitates.If not, the mechanism has diengaged.
Mar 03, 2014 | Washing Machines
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
As soon as it gets to the rinse cycle it doesn't fill up water, what can i do?
If the only time that it won't fill with water is the rinse cycle is is probably either in the timer or control board.
Have you tested it on all the the setting to determine what works and what doesn't? Will it work on permanent press but not delicate; that type of troubleshooting.
Jul 16, 2011 | Washing Machines
My LG WT-R807 8KG top loader washing machine will not rinse or spin I have a huge load in there at the moment. Have removed most of washing from it still won't drain. Have tried turning machine off and...
Did you try it in other cycles (delicate, permanent press, etc.)? The more symptoms - what works and doesn't allows better advice. Because right now it could be the control board, the timer, the drain pump and more.
Also you need to give us the model number off the id tag in your unit since that once keeps coming back as invalid.
Jul 14, 2011 | LG Washing Machines
Whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
Feb 11, 2010 | Washing Machines
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
My all in one washer dryer by kenmore is direct drive. the spin rinse spin functions work on all three cycles ie. delicate, permanent press and regular. the fill and agitate functions at the beginning of...
can you get it to start by moving the timer one more click past the beginning of the cycle? Sometimes that is all that is wrong. Other than that, it's more than likely the timer has fused some of the points together and you will need a new timer in that case
Aug 24, 2009 | Kenmore Washing Machines
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
I have a maytag washer-n-dryer(stacked). When the washing machine is filling in the wash cycle of the delicate or the permanent press cycles, it will not stop filler the drum with water. The washing...
it sounds like your water inlet valve is bad,change it,also try your washer on another water level like small load or med load and see if it cuts off,it might also be your water level switch,hope this helps,thanks-mike
Jun 02, 2008 | Maytag Washing Machines
Amana 3.2 cu. ft. Top-Load Washer Logo
238 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
