Question about Cycling
I have purchased a 2nd hand kids electric bike. it has a 6v battery and 6 rechargable batteries. it would not hold a charge and kept cutting out so i looked and the rechargable batteries have corroded so i removed them and two of the terminals are badly damaged. i cannot source anyone in the uk who can repair this for me? or give me any advice? thanks. the bike is on the website npl2.com but they are unable to help me.
  • 867 Answers
Any electronic tech will be able to replace the wires and obtain suitable batteries for the motor. its just a matter of soldering new connectors on,. getting batteries of the same voltage
Posted on Sep 05, 2009
I have an arrow electric bike that wont take a charge green lite comes on but thats it
Either the wiring to the battery is not correct or the batteries need to be replaced.
Nov 29, 2014 | Electric Health & Beauty
Where can I purchase a charger and manuel for a EZ Rider Wild Child Motorcycle
you could try the original supplier or ebay and failing that you could try searching online for a pdf manual and just buy any charger that is the correct type voltage and most importantly polarity, having looked at the bike its a childs harley type bike and is 6v 4ah and likely a sealed lead acid type so i would buy a 6v 500ma lead acid charger, if there is a charge port you will need a plug to match and you will need to check the polarity is correct or if there is easy access to the battery terminals you could just use the crocodile clips to the corresponding terminals on the battery itself there is a selection of chargers here 6V Lead Acid Battery Charger eBay a 500ma charger will charge the bike in 8hrs the higher the ah the faster it will charge but i wouldnt go much higher than 500ma without checking with the vendor that it is suitable for a 4ah battery hope this helps
Feb 22, 2014 | Toys
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
I don't know where to get a replacement battery? It shows SEL CB4-6, (6V 4AH/20HR) on the battery itself?
The replacement battery can be purchased from almost any electronic shop, Radio Shack or online at www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Aug 10, 2010 | Vector 1 Million Rechargeable Spotlight
I have a Vector HID Spotlight Power on Board SLH100P and I'm trying to recharge it. When you plug in the charger the led lights flash and click really fast. What could be the problem? Thanks for your...
The battery needs replaced. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Aug 04, 2010 | Vector 1 Million Rechargeable Spotlight
I recently bought a 2005 softail deluxe and was told before purchase the battery was going out so the seller put a new battery on before purchase. I rode the bike for approximately 3-5 days with no issues...
If you are buying a multitester also consider buying a small motorcycle battery charger. They make ones that have a remote charging cable that you put on the battery one time and then you have an easy way to connect the small charger up when the bike it sitting for long periods. This will keep the battery fully charged and ready to go when you are.
Some batteries are sold only partially charged and you need to bench charge them fully before running them on the bike. Depending on your bikes energy demands the battery may never fully charge up during regular use.
If you put the multitester on DC voltage check the battery to see what its resting charge state is.
If the battery is reading less than 10.6 volts its probably down too low the recharge itself using the bikes alternator. Charge it until its resting voltage is 12.0 volts. Then your bikes alternator can make enough juice at 14-15 volts to recharge the battery while its running.
Good luck and be careful.
Apr 19, 2010 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
Vtech Kidizoom camera. Have changed batteries but unit is not even switching on. Son has had for just over a year and it has been dropped several times.
Try cleaning the battery contacts inside the battery compartment. Do this with a cotton swab "dampened" in rubbing alcohol. You may also want to clean the battery contacts and the charging station if so equipt. Thanks, Dana
Jan 06, 2010 | Vtech Kidizoom Digital Camera
Can't get any power running on my 5500 hr life cycle
Change the battery. It is a 9v battery behind the small door on the back of the display panel.
Mar 15, 2009 | Life Fitness 9500RHRT Recumbent Bike
Cycling Logo
61 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
