Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Ok..I had to change the bulb in my 72 inch Mitsubishi Projection TV. When the tv first turns on it is fine but after about 30 minutes the colors all gets wacked and pictures starts flashing. What could be wrong now?
  • 147 Answers
The light engine has failed after on 30 min. replace light engine.
Posted on Sep 05, 2009
After about 30-60 minutes TV starts to hum and picture gets distorted, could this be the color wheel...???
Sounds like a sync problem due to color wheel speed. clean and lubricate color wheel motor with tiny amount of Z-Max lubricant (liquid Buckey balls, available at Wal-Mart), on each bearing. make sure wheel is free-wheeling and turns easily. Should cure problem. If the color wheel is in good shape, there is a power supply problem, which may be due to dried out electrolytic capacitors or a regulator that's failing. Troubleshooting or controller board replacement may be needed. Regards.
Dec 07, 2015 | Mitsubishi WD-73840 73" 3D Home Cinema...
Got a Mitsubishi vs-8070, everything works fine then the screen turns off after about 15 minutes sound still works fine. Help.
Does this unit have a projection bulb in the back end of the set? Just based on my experience with a friend's 65 inch rear projection TV, there might be an indicator light on the front panel that may blink if the rear projection bulb is failing. If there is a failing bulb it could account for the screen going black with everything else just fine, after the bulb gets heated up in 15 minutes.
Oct 15, 2014 | Televison & Video
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I changed the bulb and tv worked fine for a day. Now the tv shutsitself down after about 5 minutes.I turned the timer off and reset the system and the problem still exists,
suspect a defective lamp....by the the way, it is called a lamp, not bulb.......second, it could be the ballast......and third it could be what's called the light engine or light box........the last thing could be the color wheel. definately suspect the color wheel if accompanied by a high pitch squeal.....
Nov 27, 2009 | Mitsubishi WD-60735 Projection Television
72 inch rear projection tv took a power surge last
if ure handy pop the back off and there should be a main power board and a fuse on it, make sure you use the same fuse if it is blown do not stick another type or size in it, put it back together and turn it on if it blows again it will be somthing else if not it should work
Sep 10, 2009 | Televison & Video
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
323 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
