Question about Orbit Sprinkler System Power Source Transformer #57040
Imperial valet is an underground sprinkler and I need a manual to explain how it works .Juat moved into this house which has this system. no info
How do yo adjust and install sprinkler
The sprinkler just unscrews from the underground supply pipe counter clockwise..
May 20, 2016 | Orbit 55059 Saturn III Sprinkler w
How do I winterize my sprinkler system
Turn off the water supply to the sprinklers system.
Connect a compressor to the system and blow out the individual zones, one at a time.
You can have this done for you for about $75.00 if you are without a compressor or are unsure of the procedure.
Doing it incorrectly will destroy the underground pipes as the water will crack the pipes.
Nov 15, 2014 | Garden
Imperial valet timer
Big box stores and sprinkler supply stores.
Aug 22, 2014 | ORBIT UNDERGROUND Sprinkl pop-up 4 adj"
Wiring new sprinkler timer one wire on my old
Just cut the common wire and put one end in each of the 2 pins. The rain sensor just interrupts the signal to the valves when wet.
Nov 04, 2013 | Orbit Underground 57896 6 Station In/Out...
Trying to find a manual
1) Copy following link for sprinkler timer links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
2) Add comment March 2013 and describe timer in detail.
This will let me search files for same-similar timer, and find manuals that might be same-similar
3) Old timers, especially digital timers, are sometimes easier replaced with new.
Mar 07, 2013 | Hardware & Accessories
What are some different types of sprinkler systems i could use for my lawn at home?
the most common residential systems are impact spriklers, underground sprinklers, drip sprinklers, or oscillating sprinklers
Jan 28, 2013 | Garden
Bought a new home and need a manual for our imperial valet sprinkler system
I'm a sprinkler contractor and as far as I know that controller has not been manufactured for many years. Set the small dials for the time that you want each zone to run. Set pins on days you want to water. Set a pin on the start time for the cycle that includes all zones. Set the time and day and hope all of the motors work.
Any other questions, let me know.
Gary
Dec 14, 2010 | Garden
Can i get online instructions on how to program my
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
Jul 22, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
Orbit Sprinkler System Power Source Transformer #57040 Logo
483 people viewed this question
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
