A cone has been bent inwards. Is it possible to quickly repair? If so how?
  • Chip
    Chip May 11, 2010
    Ive used a small suction cup before to press on the cone and have been able to pull it back into shape, but that was on a large 15 woofer.
    Problem Solver:
  • 10 Answers
If you put your fingers gently on the rim or the edge of the cone and slowly bring your fingers together, the caved in part might pop out, but be very careful because this part of the speaker is very very fragile and sensitive.
Posted on Sep 05, 2009
Hi duff i went into a big hole in the road hard then the next day my tire started to turn inward and yes my shocks are over do we look under and its just band so i think we need to make it stright
from your description you have bent a lower control arm of the suspension and possible other body mount damage as well ( axle broken and is now breaking further )
Have the car checked by an accredited suspension specialist shop and get quotes to repair
The rear end wheels can be aligned so have that done at the time of the repair
Dec 11, 2015 | Cars & Trucks
My car speakers won't work 96 sunfire gt car sat 4 years
Quite possible the voice coils corroded and are stuck...assuming the battery, radio and wiring is okay. Not an uncommon problem when a car sits for a long time. You can check the speakers with a 9v household battery. Attach 2 wires to the speaker terminals and touch to the battery. The cone should jump. Also, press inward on the cones and check for roughness or no movement. Can't be fixed for a reasonable price. Replace them.
I have seen mice eat automotive wiring, especially if the car is stored outdoors. Might want to check that too!
Feb 07, 2015 | Cars & Trucks
I hit something very hard with my right front rim. the tire now rubs the wheel well. What have I bent =, dammaged ect.?
Depends on what you mean by rubbing on wheel well?
if the wheel is bent inwards, so when the steering is set straight ahead, the damaged wheel is angled inwards or outwards then the tracking arm is bent!
if the wheel well has dropped on the damaged side then it probably is the suspension!
Dec 18, 2014 | 1992 Plymouth Acclaim
Hyundai elentra bent frame and door handle
No way to tell without looking at it and taking measurements.
It may be cheaper to replace the doors than to spend the time on repairs.
Sep 05, 2012 | 2010 Hyundai Elantra
99 mustang rear tire bent inward?
Does the mustang have independent (IRS) axel or the solid 8.8 rear axel?
Jun 12, 2017 | 2000 Ford Mustang
Adjust camber right front on chevy cobalt
camber is changed by moving the bolts the hold the strut to the knuckle find more that the strut and or knuckle get bent
Jun 24, 2012 | Chevrolet Cobalt Cars & Trucks
HOW TO GLUE SPEAKER BACK TO BASKET
It sounds like your speaker surround blew away and separated from the speaker cone and/or housing. I'm in the process of fixing one my speakers by replacing the surround.
Generally, when this happens, you'll want to completely replace the speaker surround (the outer ring that allows the speaker coil and cone to travel in and out, usually made of rubber or foam rubber). This isn't necessarily super difficult, it just takes some time, skill and patience, if you want to avoid messing up the speaker and sound from it.
Inspect and repair your existing speaker:
1) Measure:
a) the diameter of your speaker cone (outer edge of the angled piece that goes inward toward the center coil) and the
b) diameter of the speaker housing (the metal "frame" part the speaker surround glues to, which is usually where the speaker mounting holes are located).
Note
whether the area on the speaker cone where the surround connects to is flat or angled.
2) Ordering: You'll want to purchase the new speaker surround to match the similar material you've already got, as close as possible to the exact dimensions you measured in either flat or angled for mounting to the speaker cone.
SpeakerWorks.com tends to be a bit more expensive than others than can be found online, and they will normally have what you need. Their speaker surround repair kits normally come with instructions, surround, glue and a little brush. I found hunting around can save 50% or more.
3) Gluing: Get yourself some Aleene's Tacky Glue (online or in craft stores), and make sure you don't use too much or too little, applying in a uniform coat on one surface, then applying gentle pressure to get the surfaces to stick, and allow it to dry completely for 24 hours.
IMPORTANT: This can be tricky, so be patient, or you're buying a new speaker. If you don't feel comfortable, take it to be repaired properly.
Typically, you'll want to start gluing the new speaker surround to the outer portion of the speaker cone, either on the underside or inside, as it was with the prior surround. Make sure it's centered, applying just enough glue with a brush to insure it holds and you can still slide everything around slightly into proper position. Gently move the speaker in and out to make sure nothing is rubbing. Allow this to dry for a full 24 hours, and do NOT attempt to glue the surround to the housing until after the cone glue is completely dry.
Now, it's at least 24 hours later, you can do the same thing by applying an even layer of glue to the surround (or onto the frame) to complete the new surround replacement. Apply light pressure to make sure it's centered, again gently moving the speaker in and out to make sure nothing is rubbing. Allow this to dry for 24 hours, just like before.
I know, impatience makes this difficult, but then you don't want to be doing this all over again by trying to move too quickly. Worse yet, you can end up completely destroying your speaker cone.
The nice thing about that tacky glue is is holds well and allows you to position things for a while before it sets. Just remember to allow the proper drying time, which is always way longer than the dry glue you can see.
Remember to defer to a professional repairman if you do not feel comfortable doing these repairs yourself.
I hope this helps!
Feb 16, 2012 | Kicker S15L7 Car Subwoofer
The right wheel is wobbly and tilts inward and outward - appears to be close to falling off... Is this a do-able repair? what parts might I need? Thanks!
Sounds like the baring has collapsed. I don't know your model but I can see from the picture it has a bicycle type hub. Check out your local owner operated bike shop. I'm sure they could help. A bicycle hub has ball bearings sitting in a channel in a inner hub and a cone shaped outer hub that is wound in to set the play. Your cone has wound out a bit, usually you wind of the outer lock nut, tighten the cone to get a free running wheel with no wobble then retighten the lock nut.
Jan 23, 2011 | InSTEP Safari TT Double AR265 Jogger
Speaker repair
Contact MMats Pro Audio at 561-842-0600. They can re-cone it for you, or sell you the re-cone kit. If that does not work for you, contact MWA Speaker Parts in Tuscon - 520-647-7193. They can sell you a re-cone kit, or they can direct you to a speaker repair center near you. A third option would be to contact Sundown Audio in Troutman, NC. They may be able to re-cone it for you.
Apr 18, 2009 | Mmats Juggernaut 15'' Car Subwoofer
Open Questions:
32 people viewed this question
 Grubhead
Grubhead
