Question about Philips Televison & Video
Geometry settings in Philips 32pw9551 rendered it useless
While changing the geometry settings in the service menu of my philips 32pw9551. The TV decided it didnt like them, and now the image shuts down within a few seconds. I suspect the vertical slope and or vertical amplitude settings to be the problem. I cant change them back without an image to delve in the service menu. Is there a hard reset possible (either mechinal or by buttons)?
3 Suggested Answers
SOURCE: Geometry settings all wrong
option settings found on small white lable on back of crt
normal code to enter service mode 062596 then index button on r/c
Posted on Oct 18, 2007
barbu51
  • 566 Answers
SOURCE: How do I adjust the screen geometry?
Sharp
Important !
After you get to the item that needs adjusting
Write down the original setting
just in case you have to go back.
1. TV unplugged
2. Press and hold the'Vol down' and 'channel up'
3. While holding the buttons, plug in the TV.
You are now in the Adjustment mode
You will be presented with a category menu containing.
Deflection
Signal
Feature
Fix Value
EEPROM
4. Use the 'Channel up'or"Channel dwn' to select the category.
note:Not all models will have 5 categories, some will jump to the 'Signal' category.
5. Use the 'Volume up' to enter the category.
6. Use Channel up and down select the item to be adjusted.
7. Write down the old value of the item before changing.
8. Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Data sheets are available for most models. These sheets list a description for each
item as well as data range and typical settings for your model. If your setting is
substantially different than the sheet then you may be developing a problem.
you want to go into deflection mode and look for pincushion items i.e pin amp,bow etc. AND don`t forget to write down original values
Posted on Nov 02, 2009
Philips magavox model 19pr15
1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
buttons.
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
Oct 30, 2007 | Philips 19PR19 19" TV
Panasonic 29 crt tv problems with the geometry
If there is a picture geometry problem, you have to check its Pin Amp section circuit inside the circuit board for any damaged component/s. If this section have any fault, the picture geometry will be distorted. Before adjusting the picture geometry after entering its service mode settings, you have to check this section first. If you want to know how to enter the service mode option window to this set, check this link.
Jan 27, 2013 | Panasonic TC-29P22R 29" TV
What are the default geometry values for 480P and 1080i FULL modes?
If you have the model listed have fun----Geometry values are depicted in the Convergence section---the grid of GREEN lines determines geometry and red and blue are then adjusted to the Green.
Primitive: Set had at one time two overlays available--clear plastic you attached to screen to line the that Green grid up against---one for 480 and one for 1080.
Once the geometry is set (best possible) you must align convergence and save it in both the modes one at a time.
By current standards a Fred Flintstone system--but in its day a real pain as alignment can take many hours with the correct remote via the tech menu for convergence.
Apr 27, 2012 | Philips 60PW9363 60" Rear Projection...
Philips 55PW9363 need convergence grid dimensions
You may not need a template as long as the geometry has not been totally lost or corrupted. How is the image in red and blue? If any of the three convergence/CRTs has good geometry, you can align the others to it. You can simply cover over any CRT whose image you wish to block out while you are aligning the others.
Feb 15, 2009 | Philips 55PW9363 55" Rear Projection...
Philips 32PW4523 with no widescreen options
no way to recover that info without obtaining a good service manual that has the default info loaded. Thats why you should always write evrything down that you change in the service menu and never change anything without having the service manual so you will know what the items sre what your adjusting. I can post a link where you can get a good service manual if you would like.
Mar 19, 2008 | Televison & Video
Philips 55pw9363 next problem
Have you change the RGB setting to Y/Yb/Yr?
You can change this option in the menu - install then go all the way to the bottom
Nov 17, 2007 | Philips 55PW9363 55" Rear Projection...
I wish I could help you but you will more than likely have to take your set to an authorized service center. Philips doesn't like to send service manuals to anyone except their service centers. Stargazer
Feb 20, 2007 | Philips Magnavox 32PS55S 32" TV
Philips 55pw9363 factory default settings
Yes,there is almost always a way! you will need the CD ROM literature for your model--it will list the normal range of settings. My reserved question is what caused the overscan and why did you decide to go in the servicer menu to "fix" the problem???? You may have some convergence issue,also.
Oct 17, 2006 | Philips 55PW9363 55" Rear Projection...
Philips 55PW9363 Service Menu - Geometry settings help, picture shifting at times???
If you are doing the labor you should wait and replace the new part and while you are at it check for loose conections in the horizontal drive circuit since all symptoms might be related,but they are doing all the work they should address all the problems you have,settings in the service menu dont just change on their own and are adjusted only when a major comp[onent has been change like the convergence.
Oct 03, 2006 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
550 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
