Question about Sony PlayStation 2 (PS2) Console
Disc not spinning browser/configuraion display on screen.
Hi,when the ps2 is turned on the green light is on but the disk does not spin,the browser/configuration comes up on the screen,unable to play any games.
  • waynethepain Dec 11, 2007
    Spot on ! blown lazer was the problem,playstation now up and running.Cheer's mate,Wayne.
    Problem Solver:
  • 6 Answers
  1. Check to see if a Music cd will spin in the console
  2. Open flip lid and examine the reset switch - check to ensure the switch is intact - you are looking for a small lever which is made of lack plastic. If its not there you need a new reset switch
  3. If the laser is not moving at all you will need to open up the console (WILL OBVIOUSLY VOID YOU WARRANTY!)
  4. Check the PCB switch at the rear of the console. This part connects to the lid of the ps2 if thats is broken you will need to replace - difficult to source but they are available
  5. Check the ribbon cable underneath the PS2 Laser for any signs of damages
  6. Check the ribbon cables x 2 which attach the laser assembly to the motherboard
  7. Remove the motherboard metal shield and test the SMD (SURFACE MOUNTED) on the underside of the board use a multimeter for this
  8. If your console passes all these tests the most likely cause is a blown laser which is a simple part to source via ebay etc.
  9. If your new laser does not fix your problem then you have a blown RS2004 chip which is expensive to replace and usually not economical to do.
Posted on Dec 08, 2007
I have a playstation 2 slim here. It wont spin the
Is that the only disc you seem to be having the problem with?? If so try getting the disc repair kit and using that. I had the same problem with mine but it was only some of the discs. The ps2 slim can be very sensitive and even the slightest defect in a disc will cause it not to recognize there is even a disc there.
Oct 17, 2013 | Sony PlayStation 2 (PS2) Console
My ps2 slim doesn't show on tv it is just black screen but the disk spins. help.........? I changed the tv cheaked the wire. other things are fine the disk spins the light is green but.... on tv it is...
Turn on the console while pressing START on the joystick 1, wait 10 seconds, release START then reset the console. If nothing appears on the screen, the console is faulty and needs to be replaced. If the console starts, replace the Modchip.
Nov 09, 2010 | Sony PlayStation 2 (PS2) Console
On switch button turns green and immediatley turns off again. My disc in the beggining stoped spinning eventhough i can here it trying to spin
Can you hear the fan spinning on the inside of the PS2? If the PS2 comes on, loads the disc, then shuts itself off, chances are it is overheating and shuts off to prevent damage. There is a small fan on the inside of the Slim PS2 that keeps it cool.
If you press the reset switch and it goes from red to green and immediately back to red without ever turning on, your motherboard is shot. ESD damage.
Nov 11, 2009 | Sony PlayStation 2 Slimline Console
PS2 does not read the disc.
Have you cleaned the laser? Try that first and if that dosen't help then your laser might be dead.
Aug 06, 2009 | Sony PlayStation 2 (PS2) Console
Black screen, no disc spin or eject, fan spins
That same thing happened to me. I disassembled the ps2 to find out the problem, I found out. If your console does not turn on or no lights check the silver ribbin connected to the reset button. See If it is in all the way the top and the bottom of the ribbin or check to see if there are any tares in it if there is replace it . You can get good parts off of Ebay.
Nov 08, 2008 | Sony PlayStation 2 (PS2) Console
ok my friend is olde and slim so what we did to temporlary fix it is clean disc and put the ps2 standing up and see if it spins . if it doenst open and then spin it by hand . then try it again contact me at and have the subject
" ps2 not spinning because i am carefull bout new viruse going around on this kind of computer
Aug 23, 2008 | Sony PlayStation 2 Slimline Console
Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
  1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
  2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
  3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
  4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Disc won't spin... laser doesn't come on...
ok...well all of you people are just **** him! the actual problem is that you probably dropped the ps2 and the case lid got a bit lose...... what you have to do (if you dont want to buy a whole ps2 case again) is tap the ps2 on the top of the lid when it goes into the cd browser screen and it will work perfectly fine just make sure you dont tap i too hard or else we will have another!
Nov 17, 2007 | Sony PlayStation 2 Slimline Console
PS2 Slim Will Not Read Games
HI Pepper,
You need to try clenaing the Laser Lens. This is done by Using Q-tip and a window cleaner like Windex. Lightly Dampen one end of the Q-Tip and swab the lens with a slight bit of aggression. Use the Dry end of the swab to dry the lens. Try it out. Also you could have your laser gear popped out. look at the long worm gear to be sure it is stuck in the black holder. This should help you. In the unfortunate event it does not, you probably need a new laser. I do think you will get it working becasue you hear the Disc spinning. If the Laser was really dead, the disc would not spin as in it cannot tell the computer the laser sees a disc. Does the same thing as though no disc is in the drive bay. Contact me at if you need service.
Nov 02, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
