Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
Bosticth framing nailer fires when hooked to air
Gun fires as soon as u hook to air supply. if u un hook from air then plug back in it does not fire until u let sit for a while without ait connected
  • 867 Answers
Seems like the piston is sticking. put 10 drops of oil in air inlet, and fire gun, try to work it loose.few drops of oil on head moving parts too will help.
Posted on Sep 05, 2009
Why doesn't the trigger do anything on my NS289000 framing nailer?
Nailer not firing is caused by lack of lubrication in the headvalve (lube with white grease) or driver stuck/bent (make sure driver moves freely) or safety foot not depressing the firing pin on the trigger valve all the way in. Easy to check. Remove the trigger to expose the firing pin. With no nails in gun, connect air and depress the firing pin with finger all the way in. If the gun fires, adjust the safety foot. If the gun does not fire, lube headvalve and check driver piston stuck. Good luck
Dec 03, 2013 | Campbell Hausfeld Ns2890 Framing Nailer...
21 degree round head framing gun wont do nothing when air hooked up
If it hit the slab it may be toast. Out of round cylinder body or head problems
Sep 04, 2012 | Dewalt D51822 Clipped Head 2Inch to...
NEW BRAD NAILER ONCE LOADED WILL NOT WORK
Many modern brad and finish nails use a sequential fire trigger system. You have to push the nose of the tool down to depress the safety THEN pull the trigger. This is the opposite of how a bottom fire works where you hold the trigger and bump the nose to fire the gun.
Mar 02, 2012 | Air Tools & Compressors
Bostich N88rh fires like a machine gun
You either have a piston stop bumper failure or some damaged orings. Look on the schematic and the piston stop bumper is number 11, part #107236. A lot of times the piston stop bumper will disintergrate due to becoming brittle from the compressed air and not having enough lubrication. Look for small plastic balls in the head under the valve. If you see little plastic pieces than that is what remains of the piston stop bumper. You will need to remove the valve from the head cap in order to inspect the bumper. Also inspect all orings. The slightest damage can have big effects. One other thing to look for is damage to the plastic valve that rides on 3 orings. (2 out and 1 in) I don't believe you have valve damage because you say it is firing like a machine gun. This is almost always the piston stop bumper.
Sep 07, 2009 | Stanley Bostitch N88rh Framing Nailer...
Porter Cable clipped head framing nailer with low miles. Driver blade remains fully extended when air pressure is applied. Gun is not recoiling the driver blade at all with air hooked up. Have...
It sounds like the firing valve in the head is stuck. Go to Dewaltservicenet.com and download a breakdown for this tool before doing anything else. The o rings are probably worn or stuck from being dry. Let me know if I can help further
Aug 19, 2009 | Porter Cable Cable No. FC350A Clipped Head...
FIRES MULTIPLE NAILS WHEN AIR IS HOOKED UP.
Your trigger plunger is not seating to close off the air. Then your safety interlock is also not working properly. Needs a rebuild of all pertinant parts associated with the firing. There is a vlve in the the body that works in conjunction with the safety interlock and the trigger.
Jul 04, 2009 | Stanley Bostitch N88rh Framing Nailer...
DeWalt Frame Nailer 51844 extends firing pin when air hose attach
Check whether the trigger is working properly, and whether the air valve is not leaking.
Jun 13, 2009 | Dewalt Round Head Framing Nailer D51845
My hitachi framing nailer blows air out the back constent
If the gun is blowing air out the back cap it needs an overhaul. If you take it to a service center they will be able to supply you with the proper O-Rings or if you pay a little more they will overhaul it for you.
May 05, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Air leaks arond trigger when depressed, but no nail fires.
Where does the air leak out from? If it leaks from the trigger DeWalt makes a trigger valve assembly part # 641006-00 list 8.89 BUT if it leaks from other areas we have to look into it deeper. If it is just the trigger valve let me know and I will give you instructions how to remove and install the new one.
Feb 05, 2009 | Dewalt Round Head Framing Nailer D51845
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
212 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
