Question about Panasonic Lumix DMC-FX2 Digital Camera
Please turn camera off and then back on again message?
Camera stopped working and just has this message in the display for all functions apart from viewing memory (pics etc) ????
Please help
I have the same problem ... It tells me to turn camera off and then back on again. The menu area is frozen as well.
Posted on Jun 28, 2008
There are several problems with my camera one of them is the fact in that Every time i turn on my Lumix 10x mega pixel camera the lens won't focus it also won't let me take any pictures. When i turn the...
OK, if there is sand in the camera, the gears will bind or stop causing the error that you described. I think it needs to be taken apart and cleaned by a service center before using again. Or you could buy a spare caemera to use on your family holiday and wedding.
  • Support: 1-800-211-PANA begin_of_the_skype_highlighting 1-800-211-PANA end_of_the_skype_highlighting (7262)
    en Español opcion #2
  • Sales: 1-800-405-0652 begin_of_the_skype_highlighting 1-800-405-0652 end_of_the_skype_highlighting
By email By mail
Initiate online repair request & check status
Jul 29, 2010 | Cameras
Camera turns on, lens cyles (in and out) 3 times, then camera displays a message "Turn the power off and on again" superimposed on the display. Image is not in focus and camera will not take picture, just...
This is lens mechanism problem and lens assembly will be replaced to fix the issue.
Lens tries to correct its mechanical error three times then gives up and you see turn power off and on again display in lcd. If camera is under warranty, please call Sony to get it fixed or take camera to local camera repair shop if its out of warranty.
Jun 13, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Wine spilled on camera
For sure your buttons are contaminated. About all one can try in this case is to take the camera apart and spray some electrical contact cleaner to try to clean it up as best you can. There are usually 5 or 6 very small phillip's head screws that hold the camera body together, but you will have to be careful taking it apart since the back of the camera is connected to the main board by ribbon connector(s). You can carefully lift the tabs on them, and disconnect them, then inspect the camera for areas that were possibly effected by the spill. Spray them good with the cleaner, and allow them to totally dry, before turning the camera back on. You can reconnect the ribbon cables to test the camera before putting it back together, and, with any luck, get it functional again. Oftentimes the damage is too severe to be remedied, even with a good cleaning, but there is always a chance. If you need to know more about the procedures of disassembling the camera, there are many videos on YouTube that show how, just looks for videos on "Digital Camera Repair". Sometimes you can get lucky and find your make and model, but they're all basically the same, with minor variations. Good luck, hope this helps, and hope you get it back into working condition!
May 28, 2010 | Olympus FE-340 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Message "turn power off and on again"
Your camera has dirt in the lens, you need to get someone to take camera apart and clean it. This is very difficult to do if you dont have any knowledge of cameras. You could send to sony, they will repair, around $95 plus shipping. Kind of expensive. Cheaper to buy new camera. But you have nothing to loose by trying to take apart clean and lube lens.
Jun 18, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Zoom will not retract
I took the camera apart, painstakingly removing all the screws. Within the zoom area were two small loose pieces, one appeared to be a lens, the other a thin metal cover. I placed the parts back into their place, and put all the screws back, except for the case. When I did a test to see if everything would work..... Eureka !!! No, sorry, Darn!
The camera appears to be at the same status, turns on long enough to see the "For Service...." message pop on the screen, then the camera powers off.
I will be taking the camera apart again, and will use a meter to check connections.
Will report back if there is further progress on this situation.
Dec 09, 2008 | Sanyo Xacti VPC-T700 Digital Camera
Using the Photosmart A440 printer with the HP M447 Camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
Jun 30, 2008 | HP Photosmart M447 Digital Camera
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Problem - Turn off and turn on again - happens repeatedly
We see this camera often because the lens gets compressed some how and the plastic gears which drive it become damaged, this would be the "buzzing" noise you're hearing during power up. The camera is not passing its power up diagnostics and therefore it shuts down. The lens is not cost effective to replace on this camera, parts and labor exceed a replacement units cost. Hope this is some help. Good Luck Joe Weibel Custom Electronics (
Oct 04, 2006 | Panasonic Lumix DMC-FX8 Digital Camera
Panasonic Lumix DMC-FX2 Digital Camera Logo
384 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
