Question about Tomtom ONE GPS Receiver
My tomtom fell off the holder and hit my shifter knob then landed on the floor i picked it up and the screen was cracked wont let me do nothin .... Can i send it in to get fixed got it last year Christmas party have a copy of the purchase
  • 333 Answers
The manufactures warranty will not cover this damage. They only cover manufacturer's defects. They will however replace the screen for you, but not without charging you a hefty price. It'll be cheaper to buy another one.
Posted on Sep 21, 2009
    Problem Solver:
  • 10 Answers
Depending on your model, your going to have to go to THIS LINK to see when your warranty is void. I'm not so sure they'll fix it for you any other way, your going to have to call customer support and they'll help you further.
Posted on Sep 05, 2009
How do I fix a broken shifter in a 2005 Suzuki Forenza
great question, how to fix.
verbs and all.
ok, a/t or m./t ( auto or stick:?)
toss coil and land (A/T)>
the shifter, is a lever.
the shifter connects to a cable
the cable connects to the transmission.
not sure what broke means, the lever fell off car?
or it wont shift. or is stuck , try to say what broken means.
but to fix it depends on which if the 3 parts are bad.
or if its park lock out feature, locking you in park.
what is broken mean. say what or post a photo.
Aug 12, 2015 | Suzuki Cars & Trucks
How to install a center console on a pacifica
Hi Melissa, I'm glad to help, here is the instruction below I said I'd send. Have an awesome day.
23 - Body/Interior/CONSOLE, Floor, Front/Removal REMOVAL [img id=LOPTableImg src="https://w05.dealerconnect.chrysler.com/service/mds2002/common/images/collapse.gif"> Click to display a list of Labor Operations associated with this procedure 1. Remove shift bezel. (Refer to 23 - Body/Interior/BEZEL, Shifter - Removal) .
2. Remove transmission range indicator surround bezel Figure 1.
3. Remove two screws attaching front floor console to the lower instrument panel Figure 2. 4. Open cup holder and remove two attaching screws to bottom of cup holder. 5. Open bin and remove two attaching screws to bottom of bin. 6. Remove front floor console sidewall attaching screws, three per side. 7. Raise front floor console and disconnect wiring harness. 8. Remove front floor console from vehicle.
374297.jpg Figure 1 - TRANSMISSION RANGE INDICATOR SURROUND BEZEL 1 - INSTRUMENT PANEL 2 - AUTOSTICK SHIFTER ASSEMBLY 3 - TRACTION CONTROL SWITCH 4 - TRANSMISSION RANGE INDICTOR SURROUND BEZEL 5 - KNOB SET SCREW 6 - SHIFTER KNOB 7 - FLOOR SHIFT BEZEL 8 - WIRE CONNECTOR 9 - INSTRUMENT PANEL WIRING HARNESS 10 - INSTRUMENT PANEL WIRING CLIP
374299.jpg Figure 2 - FRONT FLOOR CONSOLE 1 - FORWARD CONSOLE CLOSEOUT PANEL 2 - CLOSEOUT PANEL PUSH PIN RETAINER 3 - INSTRUMENT PANEL WIRING 4 - FLOOR CONSOLE BASE 5 - FRONT FLOOR CONSOLE ATTACHING SCREWS TO LOWER INSTRUMENT PANE AND BASE 6 - FRONT FLOOR CONSOLE WIRING CONNECTOR 7 - FRONT FLOOR CONSOLE 8 - ATTACHING L-BRACKETS
May 17, 2014 | 2006 Chrysler Pacifica
My kindle fell on the floor and is having problems with lighting and screen blotches what can i do?
No solution, mine fell landed in cat's water bowl, I'd love some suggestions too!!!
Jul 02, 2010 | Amazon Kindle 2
Replacing the broken cup holder
First, you must remove the floor console bezel (the trim piece that surrounds the shifter knob). The proper method to remove this involves removing the shifter knob first. This is held in by a small set screw on the "radio" side of the knob. To remove the screw, you will need a small "hex-key" (also known as Allen key or Allen wrench). The proper size is 3mm, but you can get away with using a size 7/64" if you need to. Once loosened, I believe that the knob pulls right up and off. Make sure you do not lose the small screw. Also be careful not to accidentally contact the tip-top of the shifter while the knob is removed, as this may break off the small black plastic tip, which will require much more work to repair and/or replace the entire shifter.
Next, you should be able to remove the floor console bezel by prying gently and carefully on the corners and sides of the piece with a tool called a trim stick, or if you do not have this tool, you can get away with using a small, thin-tipped flat head screwdriver. However, this will almost surely cause some aesthetic damage to the edges of the trim.
Once this bezel is out of the way, (you shouldn't have to remove the electrical connectors on the underside of the bezel for this specific job) there are 2 screws holding down the bottom of the cupholder assembly. I believe these are both Torx - type screws, which will need either a T10, T15, or T20 screwdriver bit to remove(I'm sorry but I don't remember exactly which of the 3 sizes are used). After these 2 screws are removed, open the armrest. On the TOP of the FRONT of the armrest, just above the cupholders, are 2 more screws which should be the same as the 2 bottom screws. Remove these, then lift the cupholder assembly up and forward to remove it.
To install, simply reverse the above procedure.
Because this is my first solution posted on this site, I would love to have your feedback. Please let me know how everything goes with this project. Thank you!
Mitchell
May 23, 2009 | 2002 Dodge Intrepid
I cracked the sreen on my gps
replacing the screen will cost more than buying a new or refurbished unit
Mar 11, 2009 | Tomtom One XL GPS Receiver
My digi cam fell down ???
This is going to be new camera I am afraid. The repair options are limited because of lack of parts availability Look on your local internet for repair firms in your part of the world
Jun 11, 2007 | BenQ DC3410 Digital Camera
Tomtom ONE GPS Receiver Logo
232 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
