Question about Dishwashers
Dishes don't get clean, even on heavy wash ''powerscrub''. Bad film of what seems to be detergent residue. (If it's lime we'd be replacing water heaters yearly and that hasn't happened.)
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
It is not detergent it is actually calcium. The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Posted on Sep 09, 2009
I have a Frigidaire dishwasher approximately one-year-old. Has always worked great but lately white residue left in bottom of stainless steel and residue on dishes. Have switched dishwashing detergent Ran...
Try doing a wash with vinegar. It will clean all of those hard water and soap/lime deposits away. We do this frequently (once a month) here in Dallas, TX because the water is really bad.
Oct 27, 2014 | Dishwashers
A film from the detergent seems to be left on the dishes and glasses after drying.
Look in the detergent aisle for an additive called "Glass Magic." Always use rinse aid. Adding a water softener to your house if you don't have one already. Clean your dishwasher with a dishwasher cleaning agent or something like lime away to remove any residual scum. Hope this helps.
Apr 26, 2011 | Maytag Dishwasher
Our maytag is about ten years old. No big problems that a little vinegar wouldn't solve once in awhile. Lately, we ran out of water softener salt and a white film was on dishes and not getting clean. I...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 28, 2011 | Maytag 24 in. MDB4100 Built-in Dishwasher
I get what seems to be lime scale or something all of a sudden unit worked fine untill recently film is very heavy and cannot be washed off it must be litterally scraped off . this problem is just now...
heatman101
Feb 23, 2011 | Amana Dishwashers
Frigidaire dishwasher FDB1500LFCO is not cleaning dishes properly. Glasses have a cloudy apprearance, other dishes are not clean, silveware is a mess. Have hard water so am using LemonShine for hard...
heatman101
Dec 28, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
heatman101
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
What causes white powdery residue on glassware in the dishwasher. I think it is lime deposits. Can I use lime remover in dishwasher to eliminate the buildup?
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Sep 03, 2010 | Hotpoint Dishwashers
Whte residue left on glassware and dishes
use a dishwashing cleaning agent in the machine. or some thing the has a grease cutting agent.run this on an empty cycle.
there are times residue grease and oils can accumulate down in the sump area where the water sits and can cause film on the dishes.
this could also be some lime or scale build up for that you can use some C.L.R or any kind of lime and scale remover to clean your machine.
make sure tht that this is done on an empty dishwasher
May 19, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishes not getting completely cleaned.
heatman101
Apr 28, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
There is a heavy film on my dishes. I have a rinse in it but I don't think it is being used and I use Cascade gel to wash them?
A heavy film can be the product of bad water conditions, bad cleaning action from the machine, incorrect/inadequate chemistry, and even water temps being too low.
Start by washing some of the dishes by hand to determine if the film can be removed. Use a quality detergent and some elbow grease. If film can be removed, test the machine for proper washing action. I like to do this by coating the inside of several glasses with mayonaise and placing them strategically throughout the machine. Run a cycle and ensure ALL mayonaise is removed. Is mayo removed? If no, check for plugged wash arm jets or screens. If yes, check for good water temps. 120F or higher is best, depending on machine type/model.
If machine is good and film is removed by hand, then you either have a water problem (water hardness, TDS, etc), a temp issue (raise temps above 120F), or a procedural issue (improper loading of wares, inadequate/insufficient detergent, too much food soil entering dishmachine).
Hope this helps,
Kermit
Aug 17, 2008 | KitchenAid Dishwashers
Dishwashers Logo
Top Dishwashers Experts
