Question about DCS 36 in. CP-366 Gas Cooktop
DCS 36 in. CS-366 LP Cooktop ignition
When I try to light a single burner, all igniters start sparking, and don't stop until I turn off the one I am trying to use.
  • jswarming Dec 09, 2007
    It happens with each of the six burners. The unit is sealed, how can I access the wiring?
  • Anonymous Mar 18, 2014
    I have the DCS CDT-365, when you turn on burners they click like they are trying to light but it takes 30 to 45 seconds for the first burner to light. once one is lit then the other 4 will light quickly.
  • 456 Answers
In that burner something is short check it out
Posted on Dec 09, 2007
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
When turn on by knob, all 6 burners are sparking ( no problem there).Gas goes on, but ignitor dose not shot off. (keeps cliking). Sandy.
Hi sandybaru,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 09, 2011 | DCS CS-366-SS Gas Cooktop
All 6 igniters continue to click after any one burner is turned on
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 30, 2011 | DCS CS-366-SS Gas Cooktop
DCS Cooktop CTD-365 one burner won't ignite/no spark or ticking. I cleaned ignitor.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 11, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Electronic igniters will not turn off when the gas burner lites. all four igniters run untill you turn off the nob or unplug the unit
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up.
Apr 17, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
The igniters will not stop sparking on my dcs cooktop when I turn the burners on. This happens with all burners.
Because this is happening on all burners, i would say you have a faulty ground to the ignition module.
Dec 19, 2009 | DCS 36 in. CP-366 Gas Cooktop
When i turn on a burner, it lights, but all 5 igniters continue to ignite
I have the same problem all but one burner. When using the other burners the igniters keep sparking after being lit. What do I replace?
Oct 04, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Burners ignite simultaneously (clicking)
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sep 04, 2008 | DCS 48 in. CP486GDSS / CP486GDSSL /...
DCS 36 in. CP-366 Gas Cooktop Logo
600 people viewed this question
Top DCS Cooktops Experts
Lawrence Oravetz
Dennis
Andrew Taylor
Andrew Taylor
Are you a DCS Cooktop Expert? Answer questions, earn points and help others
