I have an older model kenmore that has recently developed a problem with the water control. When setting the program to wash, the washer fills up but the water does not seem to shut off...it leaks in during all cycles...and over flows....any ideas?
  • 5,911 Answers
The water level is controlled by the pressure switch. The switch is located inside the operator console behind the load level/size selector knob. You either have a pressure switch that is malfunctioning, or something more simple. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
I would first run a small amount of water in the wash tub (about 1/4 full), shut the washer off and unplug. Open the console and see if the small air hose is still attached to the pressure switch. If not, reconnect and your problem should be solved. If the air hose IS attached carefully disconnect it and blow through it. You should get air bubbles in the wash tub if the hose is not clogged or leaking somewhere. If the hose is damage in anyway, replace it.
Double check your electrical connections and make sure the contacts are clean. Sometimes the contacts corrode with age and will not function properly.
If all these preliminary mesures do not work, replace your pressure switch.
If you need to access the interior of the washer, follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Check the lower right hand side of the wash tub. There should be a small plastic air hose attached to what is called the "airdome". If this air hose comes off, the tub will leak as it starts to fill. The other end of this hose connects to the pressure switch. Do a visual check to see if anything may be clogging it. You can remove the hose if it is clogged and blow air through it to remove most obstructions.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. Re-install washer case. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Let me know if you need any further assistance. I hope this helps you.
Posted on Sep 05, 2009
Kenmore washer model 1102781269 over fills
Possible that the settings of the water level sensor is too high, you need to short the switch and see if the inlet flow stops. if not there are issues with the main controller unit.
Check this links for tips: controller unit
Nov 20, 2013 | Washing Machines
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Kenmore model 8566645 Washer is connected and runs but water flows out of the bottom and not into the tub.
Remove the front and side panels if you haVE TO. Look for a bad water pump most common on older units.
The fill tube to the tub from the fill valve is a second likely problem
I water filter located under the tub and in line with the water pump is also a possibility.
A bad hose is not likely but a connection to a hose could be a problem.
Jul 10, 2009 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore washer only will fill to a small load water level
This is Joyce
This is your water sensor, it is going off before it lets the machine fill up, if not this then the control on your machine that determines the size load you selected. go to kenmore.com download your manuel. see what you can find out about the machine.
let me know if you need any other assistance
thanks
joyce
Feb 12, 2009 | Kenmore 23822 Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
