Question about HP ScanJet 2400 Flatbed Scanner
HP DESKJET G2410 SELF TESTS BUT DOES NOT RESPOND TO COMPUTER
EACH TIME I SEND A DECUMENT TO BE SCANNED, THE SCANNER WILL HUM AND **** A LITTLE AND STILL LIKE THAT FOR 2 TO 3 MINUTES  WITHOUT THE ROLLERS MOVING AND THEN ERROR MESSAGE WHICH READS UNABLE TO PREVIEW ,MAYBE THE SCANNER IS BEEN USED! WAIT AND TRY AGAIN!
THE SCANNER ROLLS FINE DURING THE SELF TEST!
PLEASE SOMEONE SHOULD HELP/ASSIST
PAUL AROSA
In hp g2410 scans only the page top properly , remaining page is scanned as black inB&W or greenishyellow if color
it is not a problem with the scanner,are you closing the lid everytime??,your settings are not correct,or update the drivers, HP Scanjet G2410 Flatbed Scanner
Jul 11, 2015 | HP Scanjet G2410 Flatbed Scanner
How to scan in hp scanjet g2410
First install the required drivers for the HP Scanjet G2410 Flatbed Scanner.
Simple way is to scan is use PICASA
GOTO http://picasa.google.com/
Download picasa 3.8
  1. Make sure everything is connected and turned on!
  2. Put the photo on the glass of the scanner - face down
  3. In Picasa, click 'Import'
  4. Click the arrow for the drop down list of devices. You should see your scanner listed ... select it
  5. Now you will see a screen that depends on your scanner. There should be an option to 'Preview'. Click that.
  6. You should now see your picture, there may be some settings you want to change here, but if it looks OK then
  7. Click the button to Scan
  8. When it's done scanning, you're back at the standard Picasa Import screen. Click Import all.
  9. Select a folder to put it in. I made a folder called 'Old Photos' for the first one, then, for each subsequent scanned photo, I selected that existing folder from the drop-down list.
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Scanjet G2410 Flatbed Scanner
I cant install my g2410 scanner on my laptop running windows7
Some scanner drivers are not compatable with Windows 7. Check with the brand to see if they have any drivers available.
Mar 18, 2011 | HP Scanjet G2410 Flatbed Scanner
I have a hp g2410 flatbed scanner when he scanner is powered on the light is glowing but the scanner does not make a move and is not scanning.
i have a problem in my hp scanner g2410 scaning start and the meassage displayd start the activex controll on this page
Dec 23, 2010 | HP ScanJet 2400 Flatbed Scanner
My HP F4210 can´t create PDF format from scanned documents. I run VISTA. Stefan
It's not the scanner that creates the PDF, you need scanning software capable of saving scanned image as PDF. loaded on your computer. The software determines where to send and how to save a scanned document.
Nov 27, 2009 | HP Deskjet F4210 All-In-One InkJet Printer
Problem is coming from hp g2410 scanner
Try deleting that shortcut and get a new one from the Programs folder. Find the HP scanner folder and get a new shortcut copy to your desktop.
Sep 10, 2009 | HP Scanjet G2410 Flatbed Scanner
Hp scanjet G2410 not sending email documents to outlook express
scan using Scanner and Camera Wizard
1.From "My Computer" right click the appropriate Brother FAX, MFC or DCP machine.
2.Select Get picture using Scanner Wizard.
3.Click "Next" at the welcome screen.
4.Select the save options that you require and click "Next".
5.The Wizard will now start to scan using the settings you specified.
6. Select the "Nothing. I'm finished working with these pictures" and click "Next".
The images will then be saved to the the location that you specified in step 4.
later you can attach the scanned file to your outlook express.
Sep 03, 2009 | HP Scanjet 4470c Flatbed Scanner
Not Support for Windows 2003 Server
From the HP website, on the G2410 support and drivers page: "If what you were looking for is not listed, then it is not available for downloading from the web in this OS and language" In short, you are SOL. You could try the Windows XP drivers (they'd be the closest match), but your mileage may vary. A lot. I've tried tricks such as this before with HP products with little success.
Feb 28, 2009 | HP ScanJet 2400 Flatbed Scanner
I NEED FREE SOFTWARE FOR EDITING TEST
You can download your HP SCANJET G2410 software and driver here, copy and paste this link to your address bar:
http://www.opendrivers.com/freedownload/247627/hp-scanjet-g2410-scanner-full-feature-software-driver-9.0-windows-2000-xp(x32-x64)-vista(x32-x64)-download.html
*Your vote will be highly appreciated. Thanks in advance.
Dec 26, 2008 | HP ScanJet 2400 Flatbed Scanner
HP ScanJet 2400 Flatbed Scanner Logo
198 people viewed this question
Seeker5211
Seeker5211
