Strange behaviour with my dual core system
I have intel dual core system with 160gb seagate harddisk and 1 gb transcend ram capacity. recently i exchanged my harddisk as per warranty and after installing the same i tried to format the disk by entering windows XP cd in to my sony dvd writer. it seems to be going smooth, but when 9 minutes remain to end the whole process it just hanged up for more than 30 minutes and i have no option rather restarting the system by press-hold on the power off button for a while. next time when i tried to format the same i get a message like " press any key to boot from cd " and it seems to be running suddenly the whole thing hangs up and nothing works out. i tried the same lot of time and my goodness nothing worked out. i will be very much grateful if some one can sort out the problem for me. whether is it the problem of harddisk, ram or motherboard itself.
  • 1,601 Answers
Make sure that the harddrive jumpers are set right.
Try setting BIOS to default, make sure it recognizes it..
Posted on Dec 08, 2007
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
My system will get struck suddenly when i use full screen for vlc or youtube videos etc... after restartin my system it will work normally.. sometimes my system works very slowly... i bought my system...
just try this link
and select update your driver then check
if the problem not solved replay me
Apr 21, 2011 | Intel Motherboard
Transcend 160gb external harddisk shows 149gb as i connect it to computer
The reason why you see that difference is common to all hard drive manufacturers. They determine a GB to be 1000 MB, and 1 MB to be 1000 KB, so on...
However, computers define 1 KB to be 1024 B, 1 MB to be 1024 KB, and 1 GB to be 1024 MB- so there's a reduction right there of the capacity. Add to this the overhead for a file system- and that explains the variance you see
Feb 02, 2011 | Computers & Internet
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
Iam having p3 proceessor,133mhz, 810e chipset, motherboard,512mb sd ram,80gb seagate harddisk. iwant to upgrade my harddisk like 160 gb or 250 gb. is it compatible with this configuration. ...
You can put a 160gb on it as is with no trouble, but should add ram to at least 1 gig to make better use of your system. Hope this helps:)
Aug 24, 2010 | Computers & Internet
A disk read error has occured press CTRL-ALT-DELETE to restart.
check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Maximum size of hard disk supported
Hi Bijay.
Neither is at fault. Please click on this Seagate link:
Scroll down to: Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
Follow the instruction on the web site.
This Seagate web site will help you setup the Seagate 160 drive.
If you feel the drive is still at fault you can run Seagate’s SeaTools. Click on the next link:
This software will check the 160GB drive.
(Follow the online instructions for), SeaTools for DOS.
In a Windows XP system & using a FAT 32 & a cluster size of 16kb instead of NTFS. Windows will see the total size of the drive but can only access 149GB of drive space. 11GB of drive space will be used by the FAT. File Allocation Table. The FAT is windows guide to every cluster on the drive.
XP uses NTFS & sets each cluster to 4kb. This 4kb size lowers the total usable GB size & uses more GB's for the FAT. You're 127GB size may be correct for a Win XP system using a NTFS file system. The FAT is using 33GB of drive space as a locator for every cluster on the 160GB drive.
Help with understanding the NTFS file system:
Bijay if you are still having trouble understanding please post any questions here.
Aug 12, 2008 | Intel D845GLLY Motherboard
To know good hard disk
I think that Western Digital Hard discs are reliable with affordable cost. But if you put a little money more Seagate offers better stability.
Either or else I think Transcend is your solution and it is better to go to 2GB of Ram to see better improvements.
Mar 09, 2008 | Tablets & eReaders
Linux Not installing and Not detecting Harddisk
what version of linux are you using, suse, mandriva, fedora etc...
and which release is it (eg. suse 10.1... or whatever)
Dec 30, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
