Question about Panasonic PT-47WX49 47" Rear Projection Television
Blue convergence wont work
I have a panasonic 53" rear projection. the center adjustment works both red and blue, but when i go to sector adjustments, the blue wont adjust, left or right. It will adjust up and down, and the red works fine. Is this something i can fix, and if so how?
My Zeinth rear projection HDTV the blue convergence will not move any direction
Posted on Sep 11, 2009
  • Panasonic Master
  • 3,459 Answers
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Sep 06, 2009
Is the red lamp the same size for a 53 as it is for thepanasonic
is not the same..but u can try, and then try put red convergence in others colors (blue and green) in service mode..some times works...good look.
Apr 26, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic rear projection-red convergence-moves horizontal only!?
The convergence ICs have failed. You will need to install a convergence repair kit. You can get the convergence repair kit for your model Panasonic from www.tvrepairworld.com which contains both of the Convergence ICs , the associated resistors and the cD with detailed repair instructions.
Dec 26, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Flash focus wont line red n green .... conversion problem ? I hav back off and red green blue all lit.
Try the manual convergence adjustment in the menu,if that does`nt work then you may have conv. modules problem. good luck
Nov 02, 2009 | Sony KP-53S75 53" Rear Projection...
Panasonic 53" tv pt-53wx42
your convergence ic is going bad. remove front and adjust the level of blue.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Center Target Blue Convergence and Contrast Adjustment
Yes there is a Service Code you have to have to get into Alinement menu and its a Dog following step by step to get in! (1) Turn set on cable (2) Turn sleep timer on 30 min (3) Press Action Twice exit menu 4) now tune to ch 124 (5) adjust vol half way down (6) Now Press vol- on front of TV ,now you should see a RED chk appear in upper corner (7) Now Power on remote hand unit and you shiuld be in menu Press cursor to move Mute locks where you want to aline ADJUST with vol-,Vol+ ch- ch+ for up&down back and forth.If you need anymore help let me know .
Press R-tune to change R-G-B
Dec 25, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53TW53 53 in with bad picture
Sounds like you need new convergences ICs. There are two of them in your set sometimes you can get away with just replaceing one of them but I wouldn't recommend it. They are not too expensive are 15.00 each once you replace them you have to get into the service mode and adjust the convergence.
Sep 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic t.v projector
you need to replace both your convergence ICs they are both STK392-110 you can get replacments at the following link with free instructions with pictures.
http://servicemanuals.vstore.ca/
Aug 02, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Ok, so I Replaced stk-392-110 (2) and......
Check the resistors in the red convergence circuit right next to the Ics you will need to lift one side of the resistor out of circuit to acurately check them but usually one or two resistors will be opened when the ICs go out
May 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
227 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
