Air handler and compressor on ac is not working
  • 32 Answers
Check the breakers,if they are not tripped then you have a problem with either the t-stat or the low voltage transformer in the furnace may be bad.To check for low voltage remove the front cover of the air handler and using a volt meter check for voltage between the red and common wire.
Posted on Sep 05, 2009
Cant turn off my air condoner it is on auto cool ive tried reseting it but dont work
You have one of two problems. Either you are shorted so the AC continuously gets power Or the compressor contactor has welded shut and will have to be replaced. If this is a split system with a separate air handler and condenser then it is a simple check. Turn off the breaker for the air handler and if the outdoor unit is still running then more then likely the contactor is bad.
Sep 08, 2014 | Heating & Cooling
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
The condenser unit will not kick on...it is a concord unit,10=12 years old,13 seer,3 ton. The air handler works fine. I thought it was the capacitor. The old one was bad,I verified that with multimeter....
It could be a low refrigerant cut-out (switch), grounded or shorted motor windings, open internal winding overload protector (check at the common winding), a broken conductor, or no power at condensing unit from blown fuses or open/tripped breaker.
Aug 22, 2013 | Intertherm Heating & Cooling
Lg ac shaking violently when turned on
Sounds like your fan motor is coming loose from the mounts or your squirrel cage is loose or loosening. That's just the air handler, the compressor is outdoors in the condensing unit. Pull that air handler apart and find out what's causing it, or shut it down. This can hurt you if the fan flies out of there.
Aug 21, 2013 | Heating & Cooling
Goodman compressor not running after power outage
no reset replace capacitors. check terminals on compressor to see if a wire burned off
Jul 31, 2012 | Goodman Heating & Cooling
Compressor stopped working. Air handler works okay. Checked wiring in thermostat-that is fine. Air handler is not frozen up. Breaker shows fine on meter.
Check for power out of the contactor...is the condenser fan running?? If so then the compressor should have power...could be the compressor capacitor...or a bad compressor.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
May 14, 2011 | Carrier Air Tools & Compressors
Ac sytem blows strong air but its warm
If the compressor and fan work in the outside unit, and the fan inside (air handler) works, probably the system is low in refrigerant which means there's a leak that has to be fixed and then recharge the unit.
Sep 04, 2009 | Carrier 38CKC030 Air Conditioner
Why is my air handler fan motor tripping the 20
sounds like fan motor is going bad - replace
Jun 15, 2009 | Heating & Cooling
Compressor does not turn on
Go outside and check power at the disconnect switch.
Apr 26, 2009 | Heating & Cooling
Central air and heating, not cooling
Need to have checked out by a diagnostic ac man.
Aug 08, 2008 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
