Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
DeLonghi Magnification 3300 leaking
The first problem is I can't figure how to remove the outer covers to look inside. Water is leaking onto the counter but also seems to pool under the refill tank. Replaced tank (maybe the magnet connection was failing) - no luck, still leaking. Any suggestions would be welcomed. Great machine, but not worth spending $100.00 just to ship to DeLonghi in New York. Looking to save a little by DIY. Thanks!
    President:
  • 1,618 Answers
The screws are hidden behind the water tank and inside the door area.
Posted on Sep 17, 2009
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
The plastic water line intake part cracked an is leaking, the parts book says it is part of the generator. The generator is 180.00 dollars. I just need the plastic part. Can anyone help?
I've gotten parts from and had good luck with ereplacementparts.com. Their diagram for the 3300 indicates that this is the water tube going from the pump to the generator:
http://www.ereplacementparts.com/tube-23cm-long-p-695107.html
It is less than $8.
In my 4500 unit, all of the water tubes have similar connections though in different lengths. At 23cm, this one seems pretty long.
Tube 23Cm Long
Jun 09, 2015 | DeLonghi Magnifica 3300 Espresso Machine
Leakage from bottom
open the back cover ,then the side covers and you''ll see from where the water coming.
Dec 02, 2013 | DeLonghi EAM3500 Espresso Machine/Coffee...
My Delonghi espresso machine doesn't make coffee any more. The water comes in the usual way, but doesn't go through the coffee grounds, but spurts out at the sides rather dangerously and drips a tiny bit...
I think this may be similar to a problem I have had a couple of times with my Delonghi although mine is a 3300. Anyway it seems that extended use of the machine will make the O-rings on the heating element go bad so water and steam will sprays out from the hose connection to the heating element, the fix is rather simple just have a few small containers (expresso cups) to make it easier to keep track of where the screws go, its also nice to have camera phone an take pictures as you go in case you forget how it goes correctly together. So this is what I did on my 3300.
1. Unplug machine.
2. remove water reservoir.
3. with screwdriver remove side rear and top covering.
4. on the heating element the connector is white plastic with one screw and a hose coming out. remove the screw and slowly pull out the connector.
5. remove the o-ring (likely red) go to your home improvement store and find the right size replacement, Likely in pluming or fixtures department.
6. put the new one in, assemble unit and you will have coffee again.
Note: The O-rings i have found in home improvement stores are usually black rubber rings and they dont last as long as the red rubber ring that came with the unit so you may have to repeat this in a couple of years depending on your use.
Oct 03, 2013 | DeLonghi EAM3500 Espresso Machine/Coffee...
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
My Delonghi N95 Nespresso machine is leaking water
on a N95 fill the water container and take it off the machine if it leaks its just the red seal on the botton but if thats not it put the water container back on full of water,let it sit for a bit,it wil leak out the front or side it will be the dark grey seal in the base were the outlet of the water container sits in, I found this with vmine anyway,it was hard to see it leaking but was a pain in the but!! i will talk to Delonghi or pull the seal out and match one the same
Ant
Feb 12, 2011 | DeLonghi Nespresso EN660 Espresso Machine
Water runs out of the bottom of the washer as rinse water runs in. Washer if top loading Whilrpool. Model #WTW5840SWO
Check the pump assembly ( this is a common pump ) first for a leaking problem, check fill valve, hoses, and center seal under the outer tank in the middle where the transmission goes inside the washer. The button catcher ( on older style washer ) on the side of the outer tank is also bad for leaking. See #'s 16, 17, 18 for the button catcher, grommet and clamp. Replace them all at the same time, the grommet is glued as well as clipped into the outer tank. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Changing a pump tips: This pump is pressed onto the motor shaft. The motor shaft often starts to rust and the shaft swells out and holds onto the pump...tightly!! Often need to...remove power, remove the pump clips, remove the hoses from the pump assy. if the pump assy will not lift off of the motor shaft, you may need to remove the motor & pump together and break off the pump assy. A hammer and flat screwdriver can usually crack the old pump so it can be replaced. Sand/clean the motor shaft before installing the new pump.
May 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
2,079 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
