I have replaced burt caps shorted NTE 2973Q 553, STK392-110 up grade with STK392-180s now having trouble with red and blue not locking in place .which resistors have changed in value i did have this its 4 of them 10ohms does anyone know R ____ etc.OR which ones should be replaced even if they read good ,i have replaced on some sets and it fixed them.
Comments:
Dec 23, 2007
- I found out resistors fine problem was i did not lock in convergence once alinement was done , when correctly locked in set now has great picture.when alinment is done press 7 then swap button,this locks in all alinements.
-   Hello,
My PT-51HX40B convergence is shot. I replaced both STK391-110's with no chnage. I resoldered the amps and carefully reviewed all of the solder joints several times. I have +/-20v on the amps. I don't have a schematic, but I believe there should a 2.2-ohm 1-watt resistor on each inverting input to chassis gnd? I searched and have not found these resistors. Any help with a schematic or solution would be greatly appreciated. Could the new STK's I used be duds?
Thanks,
texasdan-   texasdan
Mar 04, 2008
-   wondering, replaced stk's and now after about 45 mins the converg goes all waked. used fan to cool but no help. what's this with pressing 7 and swap to lock converg? is this on the tv remote? thnx!-   Guest
I have noted several times this statement...STK392-110
upgrade to STK392-180 or 150s.....my main OEM supply
house Andrews Electronics reports that is incorrect substitution
Best and only upgrade I use is -110 to STK394-160 Hitachi part
CZ 01341, Mfr actually Sanyo......List location and original part
number and sub you used so far for help-----.................T
Comments:
Dec 24, 2007
- Good report.....hope it holds up.........I didn't realize you were
skipping that important last step.....................T.
Only use the same part number when replacing convergence amps, or you will need to replace all of the power resistors with recommended values for the convergence amps subsituted.
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-51HX40 51 in.
Panasonic PT-51HX40 51 in. Rear Projection Television
my tv keeps on entering service mode...i know about they power and action buttons on the tv but is...
(More)
my tv keeps on entering service mode...i know about they power and action buttons on the tv but is there a way to stop it from entering service mode?
My PT-51HX40 WILL WORK FINE, THEN I WILL LOSE THE PICTURE, THE AUDIO WORKS. I WILL TURN OFF THE SET...
(More)
My PT-51HX40 WILL WORK FINE, THEN I WILL LOSE THE PICTURE, THE AUDIO WORKS. I WILL TURN OFF THE SET FOR ABOUT AN HOUR TO COOL OFF, THE PICTURE WILL COME BACK ON? COULD THIS BE THE PICTURE TUBE?
Panasonic model PT-51HX40 - the picture has been progressively getting darker over time. The...
(More)
Panasonic model PT-51HX40 - the picture has been progressively getting darker over time. The brightness is maxed out and adjusting the color doesn't help. I cleaned the top of each tube and that didn't help either. The capacitor c581 replacement recommended for the model PT-51G44 seemed like a possible fix, but the ''D'' board for this model is a little different.
