Question about Philips WACS700 Shelf System
Philips WACS700 Main Station Stuck in Booting Up Mode
Tried plugging and unplugging. The station does not respond to any other functions. Cannot be turned off manually in the usual way - only by plugging and unplugging.
3 Suggested Answers
SOURCE: Booting problem
is hard drive problem, loads of articles on web, philips should change foc
Posted on Dec 31, 2007
  • 476 Answers
SOURCE: wacs700
From HDD mode on the centre, press menu and select "Station Management".
If the option is available select "Delete Station" and delete any stations listed.
Select "Add New Station" and the unit will start searching.
On the station press menu and select "installation mode"
If this option is not available, try from another source setting, such as AUX.
Once the centre has found the station, press stop on the centre, as the station cannot connect until the centre has stopped searching.
If this doesn't work, you will have to reset both units to factory settings and start again.(Menu -----> Settings ------> Restore)
Posted on Mar 03, 2008
No power at all on station
Talk to Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 24, 2015 | Philips WACS700 Shelf System
My WACS 700 System seems to have trouble maintaining the connection between the Centre and the station
I moved my station to another position in the house and it worked  --I think originally there were too many walls between the Centre and the station
Feb 21, 2010 | Philips WACS700 Shelf System
WACS700 NOT CONNECTING TO STATION
Mine did the same, the station was trying to connect on channel 1 wi-fi where the centre was on channel 11, check under information and wi-fi for both. I then did a restore on the station, put both into installation mode and they found each other after a few mins.
Hope this helps
Jul 08, 2008 | Philips WACS700 Shelf System
Wacs700
Feb 23, 2008 | Philips WACS700 Shelf System
Station wont register
Make sure the station is put into "Installation Mode" (Menu ----> Installation mode) when you try to add station.
If this doesn't work, you probably have a faulty station.
Jan 05, 2008 | Philips WACS700 Shelf System
Wacs 700 will not connect to computer and keeps saying music centre could not be found
If you have set up the station to receive signals exactly as the manual instructs, try establishing the connection in a different room. I found that the original room that I tried to set the station up in had too much interference. Loaded fine in the kitchen.
Nov 25, 2007 | Philips WACS700 Shelf System
Wacs700
Don't use the remote control. Use the buttons on the unit. You should be able to get into Station Management then.
Nov 11, 2007 | Philips WACS700 Shelf System
Not booting
This problem is usually caused by the ribbon cable connection between the front panel and the main unit. Sometimes the problem can be cured by disconnecting both ends of the cable.
The firmware should still be ok in this case.
There are multiple processors in the WACS700 unit, and the problem occurs when they can't talk to each other.
An authorised service agent should be able to sort the problem with a replacement cable.
Oct 31, 2007 | Philips WACS700 Shelf System
WACS700/05 Wireless Music Centre will not Boot up
tried to hold source and stop got message firmware damaged retriving copy from backup. power turn off, hold down source only power on comes up booting up please wait but in the lite up mode, 30 seconds later everything back on
Aug 20, 2007 | Philips WACS700 Shelf System
Philips WACS700 Shelf System Logo
187 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
