Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Problem with Ryobi Restarting
I can get my Ryobi weedeater to start with about 3-5 pulls....the first time. If I turn it of at any time, either to replace the line or take a break, it won't start again! I have heard about changing the fuel mixture which I have, replacing the spark plug, adding fuel to the spark plug, adjusting the carb, etc, But if that was the problem why would it start so easily to begin with?
  • 127 Answers
You need to replace the fuel filter in the tank ,must be fished out of tank with a coat hanger to the filler hole to be replaced
Posted on Sep 06, 2009
I have Ryobi weedeater that has a new Carbuerator,getting gas to the cyl.an has good fire to the plug an will not start need help bad
Make sure u r not getting to much fuel. With switch off pull string twice then turn switch with throttle cable helded wide open try to start.good luck.new dose not mean adjusted good luck
May 31, 2014 | Ryobi Garden
Ryobi trimmer plus won't start. No sound at all
if it pulls super easy and it doesnt sound like the engine is even rotating when you pull it it is your pull cord assembly . basically its a giant ratchet my advise is just get a used one of a blown up weedeater it would be cheaper
May 12, 2010 | Garden
My ryobi weedeater won't start, I cannot pull thr starter , it seems to be stuck?
IT SOUNDS LIKE THE ENGING HAS SEIZED UP. IF YOU CAN NOT GET THE ENGINE TO TURN OVER BY PULLING THE ROPE THIS IS WHAT IT SIUNDS LIKE HAS HAPPENED AND THE COST TO REBUILD OUT WEIGHS THE PRICE OF A NEW UNIT
Aug 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi ss30 weedeater,if weedeater is flooded
If the spark plug is very wet, place the base of the plug against a metal part of the motor, with the sparkplug wire attached to the plug, and pull the starter rope, looking to make sure that the plug has a spark. If it doesn't, that is the problem and it may be that the breaker point gap has to be adjusted or the capacitor (condenser) has gone bad. It is not easy for folks with the typical tools of a homeowner to fix either of these problems, but it can be done. If the spark is good, pull the starter about ten times with the plug out to clear out the excess gas, dry out the plug and put it back in, then try to start it. Too much gas on the plug could indicate that you are pressing the primer bulb too many times or that the fuel adjustment is set too rich.
Jul 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi BC30 Weedeater - Cannot Start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 20, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Primer button Ryobi lawn hornet
Vacuum created by piston operation after closing the choke pulls fuel into carburetor port into engine. In much the same way as the primer bulb provides fuel for the port. These type engines usually take a few more pulls before they will start. And if there are any leaks in carb. system will be very hard to start.
Apr 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
300 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
