Question about Kenmore Washing Machines
Stopped mid cycle
S topped mid cycle full of water cannot get to do anything
after about 10 mins. beeped and flashed Ld
  • 15,935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 15, 2010
Washer stops between wash and rinse, and stays full of water. ld code
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 21, 2013 | Kenmore Washing Machines
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
I have the whirlpool Cabrio model WTW6600SB2. We keep getting the code LD when we use the normal rinse cycle. Also trying to do a clean with bleach cycle and t is supposed to go 60 mins and goes less...
The LD:
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Service Manual
More Here
Feb 03, 2011 | Washing Machines
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Just bought this washer,it is level both way.When it comes to spin cycle it stops. water is still left in tub.after a while it starts flashing LD and beeping,So please what is wrong with this machine...
I don't think this is the proper model number, I can't find anything on it. I would imagine the LD means the lid is open -- or at least it thinks it is. You may have a lid switch going bad -- Whirlpools are known for that (Whirlpool made most Kenmores) Try holding the lid down firmly where the switch is during the spin cycle and see if that makes it work. If so, replace the lid switch. Even if that doesn't help, it still could be bad, but that usually helps when they're first starting to go.
Mar 10, 2010 | Kenmore 22422 Top Load Washer
Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | LG 24 in. LD-12BW5 Free-standing...
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
