Question about Neff 23 in. T1443 Electric Cooktop
OVEN PROBLEM - NEFF Joker135 clou
I have a oven,NEFF- type : E-AP11-5 / JOKER 135 D CLOU. E-Nr:E1132W1 703.
My oven is separated from the ceramics (walling in) . The ceramics is very good and work appropriate , But the oven has some problem due to wrong use i guess.
I would like , if you can tell me a type of oven that can be combined with this ceramics , cause i don’t want change them . And here in Greece your department , claim that nothing new can be combined .
THANK YOU
nomic@aegean.gr
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sam_bbe602d2c68da69b
Aug 06, 2013 | Cooktops
Hi I have a Samsung ceramic hob that when I have the oven on and cooking veg in saucepans it cuts out randomly displaying SE flashing I'm guessing its overheating but how can I fix this ? It makes
An SE error message on the display of a Samsung ceramic hob means the control panel sensor has been on for too long.
There are a few reasons why the sensor could be saying it's been on for too long:
  • Touching the key area for more than 10 seconds.
  • Leaving a wet cloth on the touch key area.
  • Spilling a liquid on the key area.
  • By touching 2 or more keys together. All of these can be fixed by turning the hob power off at the wall, then back on again.
Jan 30, 2018 | Cooktops
I had new countertops put in and they took they drop in stove out. When complete tegy put the stove back in and everything worked fine. Within 5 minutes the control panel went off. Oven light works and...
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Feb 26, 2011 | Frigidaire Cooktops
My ceramic cooktop has cracked. Can I just order
You can get the main glass top, the part number is WB62T10525 and it runs just under $300.00, it is shown here as 51. It does take a bit of dis assembly to install it.
May 05, 2010 | GE Cooktops
Stains on black cermaic oven top
Use DeBruce Polish I guarantee great results, also perfect on stainless steel go to debrucepolish.com
Mar 06, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Child lock on for neff t1443
gud day,not all models of ceramic hob have a child lock,check it 1st ur unit if have it,if we have,touch the circle w/sign of key to lock the ceramic for ur child,to unlock touch again.u see the ligth red is on it means the lock is in ON.easy to unlock even ur child by touching the key sign,for ur safety to not use ur unit,unplug the unit if it not use.
Aug 21, 2008 | Neff 23 in. T1443 Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Neff 23 in. T1443 Electric Cooktop Logo
135 people viewed this question
Top Neff Cooktops Experts
Samyfam
Samyfam
Paul Carew
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
