Question about Maytag Washing Machines
Washer spins so hard, washer moves across floor
  • 26 Answers
If the washer is old, the snubber pads will need replacing and greasing. This requires special tools for disassembly to the point where one can perform the required service.
If the washer is less than a few years old, the issue is simple leveling.
Look under the front edge of the washer and locate the leveling legs and locking nuts. Using a crescent wrench, free the locking nuts and re-level the washer, re-tightening the locking nuts.
Posted on Sep 08, 2009
How do I balance a Kenmore HE2 Front Load Washer.
You need to level the washer. They also have things to put under the feet to keep it from moving. Or try to block the feet.
Jul 05, 2014 | Kenmore HE2 Plus Front Load Washer
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
The tub is very wobbly and the machine was loud and moved across the floor when the spin cycle was on
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
JUST GOT A NEW FRONT LOAD DUET WASHER - 3.7 AND IT IS KNOCKING AND MOVING ACROSS THE FLOOR. IS THIS A PROBLEM WITH THE MACHINE OR WHAT?
check to see if the shipping rods have been removed,also if machine is located on upper floor laundry room,the floor may not be sturdy enough to counter act the force generated during spin,this is a common issue in newer homes
Mar 10, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Unit shimmy's across floor
Remove the two support bars from below the washer drum from the front as instructed in the installation manual
Jan 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
My bosch washing machine keeps moving across the floor - we have tried to balance but on the spin cycle - it still moves
either ur drum is loose or ur floor is realy bacd. Dont forget that most macianie have adjustement screewed
Nov 19, 2009 | Bosch Axxis WFL 2060 Front Load Washer
New front load washer dryer is vibrating badly when drying
Q - My washer keeps moving around n the floor, is there any simple things that I can check ?
A - Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Mar 14, 2009 | Samsung B1245 Front Load Washer
Maytag Nepture washer shakes across floor
iff you remove the door assy 2 screws holding it on) andthe n the 2 screws opposite the hinge, youll be able to remove the front cover and look at the inner workings of unit, perhaps a shock absorber has broken causeing the vibration
Feb 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Sep 19, 2008 | Admiral AAV7000A
Front load washer- spin cycle is like a hurricane
be sure all the shipping materials have been removed ..next adj all feet up as close to bottom of washer as possible ..try rocking machine ..if movement detected adj only foot necessry to firm up washer ..still have vibration suspect floor ..front washers need a good SOLID floor
Aug 16, 2008 | Washing Machines
Washing Machines Logo
98 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
