Question about Saws
My Delta band saw motor is having issues. I was
My Delta band saw is having issues. I was using the saw and the saw blade suddenly slowed and stopped. The motor then made a humming sound, but motion wasn't delivered to the saw. The saw itself is not jammed; it still moves smoothly. It seems to be a motor problem to me. Any suggestions?
    Sergeant:
  • 217 Answers
I would bet it's the Motor Brushes.They are locaded on the housing of the saw, accesed by unscrewing the plug.The brushes are replaceable and your saw will be fixed.Where to buy replacents could be an issue,Check manufacturer or search power tool replacement motor brushes.If stuck you can try to unscrew the plug the brush is at the bottom engaging the motor armerure,there shoud be a spring keeping contact.Inspect brush condition it looks like a carbon block worn to the curve of the motor.Go online do a search on how electric motors work you'll see exactly what I'm explaining.Cheap part easy fix.Good Luck.
Posted on Sep 05, 2009
What are all yours phone number
I ordered my band saw blades on sawblade.com . I mostly cut metal tubes and some pipe work. I used bi metal band saw blade.
May 21, 2014 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
The blade will stop in the middle off a cut
A good quality sharp blade may make all the difference in the world, but make sure the belt is not slipping first.
What are you cutting ? Do you have enough HP ? Make sure you're feeding the material properly, not too fast
or not too slow. I suggest you to check the Carbon blades from sawblade.com .
Apr 19, 2014 | Delta BS100 Shopmaster 9 Inch Bench Top...
Motor replacment
Try to contact ereplacement . Or check out the motor from Baldor electric company. They have available motors. If you need band saw blade, my supplier is sawblade.com . Check them out.
Nov 11, 2013 | Delta Machinery 14" Band Saw with 1HP...
Delta 28-160 band saw 3 wheel, blade keeps coming off
Sounds like your tracking screw needs adjustment, located right beside the knob used for tightening after adjusting the tension on the blade. Allen wrench required. Turning right pushes out and turning left pulls it in. A little is a lot when adjusting this screw. Always turn the blade in the same direction as the cut while adjusting.
Nov 27, 2012 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
The blade on my 28-150 has started popping off the wheel as it slows to a stop after the machine is switced off
This sounds like the blade tension is too low. You might want to keep the tension low when not in use, then tighten it up when you want to use it.
Jan 14, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
Delta Bench Band Saw Model 28-185 has frozen up. The blade will not move. I topped and cleaned out all debris and let it cool down but it still will not work
You need to find what is jamed. Loosen the blade tension and take the Blade out. Check to see what doesn't move:
Wheels, or Motor. Unjam as required.
Jul 08, 2009 | Delta Saws
Band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Mar 31, 2009 | Delta 28 168 Bench Band Saw Blade 56 1/8...
Delta shopmaster bs 100 band saw
Hi, This Delta saw uses a 59 1/2 inch blade ( 1511mm).
Good Luck, this should Fixya!
Mar 06, 2009 | Delta BS100 Shopmaster 9 Inch Bench Top...
Saws Logo
166 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
